4.5 valve clearance
jonathan
Full Name: Jonathan Venter
Nickname: jonathan
Home Town: Jacobsbaai
Current 4x4: 2005 4.8 GRX
Has thanked: 9 times
Been thanked: 43 times
4.5 valve clearance
Post by jonathan »
Hey guys, need some advice please!
I am adjusting the valve clearance on the Troll and just need some input on the size of the gap. After stripping everything and getting the cover off I ran out of time (moet dit na werk probeer doen!) so now I will have to set the gap when cold. I know the manual says a gap of 0.2mm when cold but I have a feeling that this is when the motor is being re-assembled and just to get it going and then you need to set it again later when hot? I definitely do not want to assemble everything, run the motor and then strip it again!
The gap of 0.2mm just seems a bit too small compared to the gap when hot. Shouldn't the gap become smaller when hot? (Ek moet nog die termodinamika van Troll engines gaan opswot!) Does anyone else have experience with setting the gap cold and what should I set it at to be safe? Wil nie graag nou al valves brand of slaan nie!
Jonathan
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Re: 4.5 valve clearance
Post by Russ Kellermann »
Hi Johan, i saw your query and it reminded me of a thread some time ago. haver a look by clicking on the link below. I put the clearances in for the 4.5 from my Max Ellery Patrol Manaul.
http://www.patrol4x4.co.za/viewtopic.ph ... ces#p15709
jonathan
Nickname: jonathan
Post by jonathan »
Thanks Russ
Those are the same clearances as I've got in my manual. Well I've set the clearance and will start up the Troll tonight after contorting myself to change the plugs!
Jonathan
:lol: :lol: .... changing plugs can't be worse than changing the spark plug on the no 6 cylinder of a VG30 Nissan Sani motor.... :lol: :lol:
Houdini would have even used a few strong words if he had to do that....
Good luck with the start up !!!
jonathan
Nickname: jonathan
Post by jonathan »
Cedric I think those Japanese engineers are a bunch of masochists! Changing the no 6 is the worst part of the job!
The start-up was fine but not without a few harsh words!
Russ Kellermann
great news johan.
What is the benfit of adjuting the valve clearances and should one do so avery so often? I drive a TD42 (4.2 diesel pickup) with 150 000km on the clock, i am wondering if i need to adjust mine,...what would indicate this?
jonathan
Nickname: jonathan
Post by jonathan »
Russ I'm not sure if there are definite intervals at which the clearances need to be set. I just did mine because the rockers were excessively noisy. Which means that the valves are probably not opening as much as they should which could influence performance and maybe durability. Well I'm not a pro but that's my understanding anyway!
I got the page out of nissan manual on my desktop will scan and post when in the office some time over weekend !!then its there for futture ref
:thumbup:
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
From the Electronic Service Manual....
4.5 Valve clearance
4.5 Valve clearance
:thumbup:
