Lets talk radiators
Has thanked: 62 times
Been thanked: 258 times
Lets talk radiators
Just before my immediate past trip (around the Okovango), I picked up that the original copper/brass radiator in Skilpad has developed a small leak.
In Maun last week, just before leaving civilisation, I gave the radiator some scrambled egg for breakfast (an old bush trick). This certainly did the job and I got through the trip without any further leaking. The long term solution cannot be the occasional egg in the morning though.
However, I have for a while been mulling over the effectiveness of my copper/brass radiator in my 4.8 GQ. The radiator is still the original from the TB42 carburattor engine (if original it is therefore more than 20 years old). Before the leak though, the cooling was in any event not as effective as it should be. But this is in no small measure also due to not having a cowling at the moment.
So I have been doing some desktop research (read "internet") on options.
One big debate is the copper/brass original factory radiator versus after-market aluminum radiators.
The following links were informative:
https://www.cgj.com/2013/06/27/aluminum ... at-debate/
https://www.cgj.com/2013/06/28/aluminum ... fferences/
https://www.cgj.com/2013/07/02/aluminum ... ptibility/
https://www.cgj.com/2013/07/10/aluminum ... intenance/
https://www.cgj.com/2013/07/16/aluminum ... -thoughts/
To spare you the detail here is the decision making final summary:
Use aluminum if the following apply:
a) The original radiator was aluminum
b) Space under the hood is limited
c) Air flow or over-heating is an issue
d) You add a bigger engine to a vehicle
e) Weight is a major consideration, such as in racing
f) The vehicle or equipment needs a heavy duty radiator to withstand additional pressure and heat
g) You are unsure of which type of radiator to use
(b), (c), and (d) certainly applies to Skilpad and possibly (f) given the hard work we put our cars through, in sand, rocks (slow moving) and dunes. Often in extreme conditions.
And here is an interesting final thought:
"Copper-brass radiator can still be used if your vehicle was designed for it. Typically this applies to antique vehicles using original parts. If you are working hard to maintain the original look of the vehicle, then you should stick with copper-brass. On the other hand, if you have heavily modified your vintage car, you may need to switch to an aluminum radiator."
So if your GQ is still original (such as the TB42s) then sticking to copper/brass is still recommended.
Has thanked: 1136 times
Been thanked: 1047 times
Re: Lets talk radiators
Alex, I am not entirely sure all GQ's came with copper radiators.
Mine certainly had an Aluminium one in when I got it, and it certainly looked like a factory item.
Also, I think any car with aluminium in the engine should ideally not have any copper or brass in the cooling system.
Interesting if they came out with either material, may depend on the factory of origin...
With aluminum in the engine...
So if certain parts of the engine is made of aluminum it should be an aluminum radiator?
Does that not then apply to certain parts o the TB48?
Definitely. All the TB engines have Aluminium cylinder heads.
There is a relatively large electrical potential difference between Aluminium and Copper.
At least with the TD42 you don't have that problem, but with the TD's reputation for overheating...
I dont think the original coper radiators were produced for a spesific reason besides it was the common material to be used 30 years ago.
There is abselutely no benefit in using a coper radiator instead of a alluminium one. The alluminium radiators run around 10 deg cooler on the diesels and they weigh 3 times less.
The size is not relevant as Universal coolers can copy the original radiator to the mm.
Alli is the way forward .....we saw it afer pleanty testing ect ....the heat exchange happens so much faster . Just dont paint it it makes problems if you do that . Mr Boegman went for one also for his GQ iam sure they have the drawings ....
Getting a shroud to fit will be the bigger problem but We have a lot of guys with proper measuring abilities 😃
Also ask Mr Slang what a diff it made in Chuck
Universal does shrouds too.
My shroud may differ from Boegman due to the 4.8 viscous fan
Jip ek dink jy moet dat ons mooi meet daar
bogeyman
Full Name: Christo Boegman
Nickname: Chris
Current 4x4: 2005 4.8 GRX
Been thanked: 102 times
Post by bogeyman »
Yes , the copper radiator in my GQ was very well used.
I took the whole car to Universal and they took measurements , but did not look happy.
After paying the deposit and waiting 6 weeks I then removed the old radiator and they used it to make exact drawings.
I had a tough time convincing them to include the additional pipe for auto box oil. This helps to keep the auto box temp correct (hot and cold.).
The new radiator works so well that I thought the temp gauge was faulty as it did not move from cold. Faulty thermostat is to blame and the car ran close to normal with it and the old radiator. Got the temp up to 2mm from cold on Sunday up the trail. New thermostat on the way.
Cost me R8800.00.
Users browsing this forum: No registered users and 17 guests
