Engine cut-out
Bossie
Full Name: Andre Wynjeterp
Nickname: Andre
Home Town: Paarl
Current 4x4: 98 Patrol 4.5 grx
Engine cut-out
Post by Bossie »
Hi guys
Bought a 4.5GRX early Jan. Whilst driving the other day the engine just died on me. Engine tries to run but just dies again as if not enough fuel.
Records show that a new fuel pump as well as relay fitted just before I bought it. Help,
Picasso
Full Name: HS
Nickname: Picasso
Current 4x4: Nissan Patrol
T3 Syncro
Home Language: German
Has thanked: 10 times
Been thanked: 44 times
Re: Engine cut-out
Post by Picasso »
Hallo Andre
Normally I would suggest to have it checked out by Graham.... but I see you are in Paarl.... which might be a bit to far.
My question would be... is it the right fuel pump which was fitted to your vehicle ? :think:
check the previous write up:
http://www.patrol4x4.co.za/viewtopic.ph ... +fuel+pump
good luck :thumbup:
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Been thanked: 53 times
Re: Engine cut-out
Post by Chris Skinner »
With weak battery and alternator problems engine can also cut out. Happened to me, no indication of failure on instrument panel.
Re: Engine cut-out
Alternatively.... In Belville you can speak to Frans ( Tour de Frans ). He will definitively be able to sort your Patrol out !!
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Re: Engine cut-out
Post by JoshJ »
Bossie, congrats on your buy. Maybe you should have bought a ZD30. They go and go untill they say BOOM. The dont have all these small niggles like the petrol Patrols have. Irritating little faults.
Just kidding man.... I see you are new. We have to throw in some humour no and then on the forum ne. So dont take it to serious.... QQQ :lol:
Being alive is a Blessing!!
Joshua
Re: Engine cut-out
hahahahahahah,..... :rolling: :rolling: :rolling:
Re: Engine cut-out
Take your Troll to Frans Fourie. He will sort it out.
Bossie
Nickname: Andre
Home Town: Paarl
Re: Engine cut-out
Post by Bossie »
Thanks you all.
Where do i get hold of Frans. Previous owner adamant that correct pump was fitted. Hy glo daar is n elektriese probleem. Dit lyk nie goed nie, ek moet die patrol rond sleep met my Ranger 3.0 diesel.
Re: Engine cut-out
O8drie40nege 250nege bel hom
Bossie
Nickname: Andre
Home Town: Paarl
Re: Engine cut-out
Post by Bossie »
Will keep Frans in mind. Problem solved. Positive wire running through fuel pump housing making intermittent contact. :blonde:
