Radiator Cap
Tiny Howarth
Full Name: Graham Howarth
Nickname: Tiny
Home Town: Walvis Bay
Has thanked: 31 times
Been thanked: 25 times
Radiator Cap
Post by Tiny Howarth »
Existing Cap Genuine Nissan 1.2Bar
Hand Manual
Radiator
Unit: kPa (bar, kg/cm2, psi)
Cap relief pressure
78 - 98 (0.78 - 0.98, 0.8 - 1.0, 11 - 14)
Leakage test pressure 157 (1.57, 1.6, 23)
Nissan according to my van VIN number 88kpa (0.88bar)
Will this make a difference if i fit the Nissan 0.88bar. :helpsign:
Has thanked: 1140 times
Been thanked: 1049 times
Re: Radiator Cap
The difference in boiling temperatures between those two pressures is 4.7 degrees. So your car might boil earlier.
If you prevent it from boiling, there will be no difference.
Tiny Howarth
Nickname: Tiny
Re: Radiator Cap
Thanks Peter, will go then for the available Nissan cap 0.88bar, don't intend to boil :biggrin: rather stop for a whiskey and wait cooling down, done this before with my V8 Landcruiser :thumbup:
Re: Radiator Cap
the VIN number spec is for Europe conditions. The AFRICA Nissan operates in much higher altitude adn higher ambient temperatures
Stick to the 1,2 bar Africa specs
blizzim .. kjyk watse flerri grend Ingils raak ik hier kwyt.. wag, laat ik n pillikji loop gaat syp .. :oldtimer: :oldtimer: :oldtimer: :oldtimer:
Tiny Howarth
Nickname: Tiny
Re: Radiator Cap
Thanks, will order correct one from Nissan today :thumbup:
