ACS
Brackenfell
021 9827114
Did not measure outer diameter, i took off the original fan and put up against the new unit OD, Pitch and 7 Fin Blades exactly the same except the recess on the fastening point to viscous was 5mm more deeper than the original, the 5mm made no difference, at first i thought might touch radiator, but did not. If you really need diameter i can get a caliper tomorrow and measure, please let me know.Etienne Gous wrote:Good Job
Please give Fan diameter, number of fins and does the pitch compare to std
I took some pictures a couple of minutes ago on my cell, will send tomorrow my cell USB cable at work.Tinus lotz wrote:Put a picture
