od meter resets on start up.
Oellie
Full Name: R.oelofse
Nickname: Oellie
Home Town: Walkerville
Current 4x4: 2005 Patrol 4.8
Been thanked: 7 times
Post by Oellie »
Hi guys
Have any of you guys ever had the problem that the odd meter resets on the dial cluster on start up ?
The fuel gauge as well the temp gauge drops on crank up. :helpsign:
Any suggestions into what the problem might be will be highly appreciated.
Re: od meter resets on start up.
Not too sure, but could it be that the battery is a bit old and tired and has just enough oomph to crank the motor but the amps drawn are too high and there is then not enough power to run any other electronics while cranking to start
gupster
Full Name: Barry Guppy
Nickname: Baz
Home Town: Hibberdene
2005 Nissan Patrol 3.0 GR
Has thanked: 136 times
Been thanked: 31 times
Post by gupster »
I too am not sure what the fault could be, but I believe a lot of problems can be caused by earthing issues. Have you got the ref document for the Patrol? Section 46 might be the solution you are looking for. I tried to copy and paste it but failed. Tried again, hope its there, its just the one page
Kind regards.
Barry
ZD30 Y61 Reference Document - Colour.pdf
(376.56 KiB) Downloaded 169 times
Have Troll, will travel.
That could well be the reason Ollie... after the Patrol having its first...... and last swim, the earth connection may have gotten a little rough, and not making a perfect connection
Oellie
Nickname: Oellie
Post by Oellie »
Thanks guys
The swim did a lot of strange things to the troll and it's owner :biggrin:
Users browsing this forum: Majestic-12 [Bot] and 1 guest
