Fluctuating Fuel Gauge/Spot lights link
Whilst en route from Port Elizabeth I noticed that as soon as I switch on the spot lights the fuel gauge starts fluctuating. When spots are switched off the fuel gauge returns to normal. I have a set of Hella FF500 55Watt spots which are fitted in accordance with the Hella instructions using the Hella supplied wiring, relay and switch. There is no link between the spots' wiring and the fuel gauge.
I can only think that the wiring might be too thin or that the relay is inadequate :think: . Anybody have any other ideas? :helpsign:
Has thanked: 189 times
Been thanked: 270 times
Re: Fluctuating Fuel Gauge/Spot lights link
Hauw, mine does exactly the same :redface: But seeing that to date I have only driven my Patrol that once up from Cape Town and not had the chance again :cry: I thought I might have been imagining it :rolleyes:
If anybody has a solution to this - pls advise
Tinus
Jy het mos 'n elektriese agtergrond. Gee bietjie raad seblief.
Has thanked: 1124 times
Been thanked: 1038 times
Jorrie, Tinus toer op die oomblik in Europa en sal sover ek weet omtrent die 15de eers terug wees.
It sounds like a bad earth connection to me, but where I can't tell you. It could conceivably be the main earth between the battery and the body, but this is probably unlikely. It could be either of the two earths on the spotlights (switching line earth or main line earth), it could be the fuse boxe's earth or even the instrument cluster or the gauge sender unit's earth.
Dankie Piet
Ek sal die naweek al die earths nagaan.
Voorspoed Jorrie
Aries66
Full Name: Louis Naude
Nickname: Aries66
2011 Navara 3.0V6 V9X
Post by Aries66 »
Jorrie ek is seker dit moet daai computer box van jou Trol wees, hy reken seker so as daai spots brand soek
Jy na iets voor in die pad en dit moet net petrol pomp wees waarna jy soek so hy se jou gee my aandag. Ek is DORS :blonde: :blonde: :rolling: :rolling:
Na ek die spots se "Earths" verwyder het en direk aan die negatief van die battery gekoppel het is die probleem weg. Ek toets dit nou oor 'n periode van drie maade en nog geen probleem nie. PC se eerste idee oor die "earth" was reg!! My ligte se "earths" is nou direk aan die negatief van die battery gekoppel en alles is 100%.
Thanks Piet. :thumbup:
Jorrie ek is bly jou probleem gekry miskien moet jy net kyk na jou hoof aard tussen battery en body kyk dit kan probleme op ander punte ook gee :mytwocents:
Tinus
Die hoof aard is OK. Die probleem het by die tipe verflaag van die bosbreker gelê
