Pardon my ignorance
- Adamastor
- Full Name: Hannes Baard
- Nickname: Adamastor
- Home Town: Hermanus
- Been thanked: 3 times
Pardon my ignorance
Hey guys
I'm tentatively looking around to trade my Navara for a Patrol.
As I scout around, I see suffixes to the model numbers such as (C87), (P64), (P71) etc.
Sometimes the same year model have a different suffix.
Can someone please explain this to me?
2009 Nissan Patrol 4.8 GRX - soos sy van haar ma af kom...
- Has thanked: 1141 times
- Been thanked: 1049 times
Re: Pardon my ignorance
Adamastor, I have not seen those model number suffixes you mention, where did you see them?
- Adamastor
Hey there guys...
Found this site where the numbers are quoted directly with a year model.
It seems it reflects the different trim levels...
http://www.um.co.za/specifications/nissan.aspx
Still have to dig deeper... have not found the (C87)... but maybe it is not even needed, seeing I only have to look as far back as 2004 which was the (P64) for my purposes...
- johanp
- Full Name: Johan Pheiffer
- Nickname: Johan
- Current 4x4: 2004 Patrol 4800 GRX
- Has thanked: 1 time
- Been thanked: 26 times
As far as I know the C87 is from 2002 to early 2004 and the P64 is the late 2004 and on shape.
- David
- Full Name: David Prinsloo
- Nickname: David
- Home Town: Stellenbosch
- Been thanked: 49 times
1 First generation (4W60 series; 1951–1960)
-----1.1 4W70 Series
2 Second generation (60 series; 1960–1980)
-----2.1 Jonga
3 Third generation (1980-1989/-1994)
-----3.1 160 Series (MQ / MK), 1980–1989
-----3.2 260, 1986–1994
4 Fourth generation (Y60; 1987–1997)
5 Fifth generation (Y61; 1997–Current)
6 Sixth generation (Y62; 2010–)
Check out: http://en.wikipedia.org/wiki/Nissan_Patrol
-----2.1 Jonga
- Adamastor
Thanks Johanp
I have seen those suffixes listed in the "boekie" that is used by the second hand trade.
The Patrol 4.8 GL from 2004 to 2011 (190kW) is also identified by the suffix (P63)
And yes the Patrol 4.8 GRX A/T (185kW) from 2002 till 2004 is identified by (C87)
And finally the Patrol 4.8 GRX A/T (190kW) from 2004 till 2011 (P64)
Nissan South Africa on the other hand, lists the latest 2011 models as follows:
3.0 TD GL 4x4 M/T and Adventurer 60 3.0 TD GL 4x4 M/T (118kW) - Model Code (P73)
4.8 Tiptronic GRX 4x4 A/T and Adventurer 60 4.8 Tiptronic GRX 4x4 A/T (190kW) - Model Code (P74)
So the above is the trim and/or appointment standard (iow what kit comes standard) and...
The current "Y" designation refers to the "Generation" or overall body and mechanical configuration (the shape if you will)
Now I also understand....
Thanks for all the input guys...
Daar leer ons ook iets.
Thanks Adamastor
Thanks Adamastor
Users browsing this forum: Bing [Bot] and 4 guests
