2-stroke oil
davejones
Full Name: David Jones
Nickname: David
Home Town: Lagos, Nigeria
Been thanked: 6 times
2-stroke oil
Post by davejones »
Are any of the diesel owners using 2 stroke oil? I've read a bit about it; not sure how necessary in South Africa?
An ox, but with balls !!!
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Re: 2-stroke oil
Post by Stefan »
Nope, only Delo 400
Ross
Full Name: Ross Holland
Nickname: Ross
Home Town: Cape Town
aka "The Polar Bear"
Has thanked: 7 times
Been thanked: 14 times
Re: 2-stroke oil
Post by Ross »
By "using two stroke oil" I take it you are referring to adding a small quantity of two stroke oil to every tank of diesel??
I`m not sure its "necessary", but after doing some reading on the potential benefits, I`ve been adding 500ml of two stroke to every tank for the last 6 months or so. The difference is subtle, but the Troll runs noticeably smoother especially when cold. From what I`ve read this would mostly be attributed to better lubrication of the injector pump.
:mytwocents:
Ross
tour de frans
Been thanked: 22 times
Re: 2-stroke oil
Post by tour de frans »
:thumbup: Ross
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
davejones
Nickname: David
Re: 2-stroke oil
Post by davejones »
To be more specific - 2-stroke added in with the diesel!
Thanks Ross; I think i'll give it a try. I read on the LCCSA site that up on the reef during winter it is beneficial; but needed a second opinion from a PATROL owner :biggrin:
Re: 2-stroke oil
I have been doing this trick for a long time. I had an Isuzu 280 DT, with 500 000Km with still the origional un-opened turbo and origional un-opened motor. Slightly more smoke, but nothing major. I still add 2 stroke to my 3.0 V6 petrol SANI. Reason.... lubricate the the pumps and injectors etc.
Will deffinitely do this with the Maiden. She likes a little extra lubrication....... :inlove: ..... :rolling:
SRXy
Full Name: Wes
Nickname: the Knob...
Home Town: Slaapstad
Current 4x4: TD42T Patrol "The Wee Beasty", 373,000km's
Umm....this is a Patrol forum isn't it?
Home Language: engles
Re: 2-stroke oil
Post by SRXy »
The two-stroke lets you wheelie lekker....hehehehe
I'm seriously considering giving this a go.....my only concern would be long term tarry buildup on the injector tips and pistons heads. But I suppose a good flush with injector cleaner every 5000kms or so should sort that out. Any of the gearheads have any other info?
Izak
Full Name: Izak
Nickname: Sakkie
Re: 2-stroke oil
Post by Izak »
Been doing it since Arnord from CRD in Alberton gave the advice. No negative in it in more that a year of use.
Re: 2-stroke oil
It may be in my head.... but I think the Maiden has a little more oomph :deathmetal: ... and only a fraction more smoke.
