Power Window motor - where to get?
Florian320
Full Name: Florian M.
Nickname: Flo
Home Town: Hoedspruit
Current 4x4: '99 GRX 4500
Home Language: German
Has thanked: 42 times
Been thanked: 34 times
Post by Florian320 »
Good morning!
My front passenger side power windows motor seems to be running hard and I would like to replace it.
The assembly is running nice and easy, it has to be the motor.
Is there any source where I can get a new one, including the drive gear for the regulator?
I have a feeling that you can't get them from Nissan anymore, so a different company would be highly appreciated.
The original part number seems to be 80731VB011 replaced by 80731VD21A.
Best regards,
Florian
Spike
Full Name: Spike Pretorius
Nickname: Spike
Home Town: Milnerton
Home Language: Sleg soutpiel
Has thanked: 77 times
Been thanked: 87 times
Re: Power Window motor - where to get?
Post by Spike »
Lubricate the groove in the door surround using silicone spray. It gets tight after a while
:oldtimer:
Sardonic Fattist
Florian320
Nickname: Flo
Hi Spike,
thanks for the reply.
I did lubricate everything: the glas-run-rubbers, even the regulator assy itself which was running easily before.
Moved by hand the window also slides easily, so it should be the motor.
Overambitious
Full Name: Conrad Osterloh
Nickname: Conrad
Current 4x4: Nissan safari
Has thanked: 1 time
Been thanked: 4 times
Post by Overambitious »
Check the voltage at motor. It could also be the contacts on the switch that have burned and the motor isn't seeing a full 12v
Sent from my MHA-L09 using Tapatalk
Florian320
Nickname: Flo
I have cleaned the switches already with just a bit better results.
My idea (but I might be wrong, that‘s how I try to explain the issue) is, that the motor is running not so easy anymore and therefore more current flows through the switches which makes them loose their good contact.
But in the end a tough running and therefore power consuming motor will only make it worse.
I‘ll try to build something that I can put direct battery-power to the motor an see wether it is better then.
It‘ll just take some time before I will be able to do that, will post an update then.
Thanks for your help!
Florian
izakjbrt
Full Name: Izak Joubert
Nickname: Izak
Home Town: Ramsgate
2012 Patrol 4.8 GRX (MA-trol)
Has thanked: 235 times
Post by izakjbrt »
Yeah on my Patrol, its only the drivers side switches that works for the other windows, not the passenger or the rear door switches work. Only the central console
2007 Nissan Patrol 4.8 grx
Invite me for a braai and let me check the reasons of this for you. :)
izakjbrt
Nickname: Izak
Home Town: Ramsgate
Post by izakjbrt »
iandvl wrote: 14 Jul 2022 19:24 Invite me for a braai and let me check the reasons of this for you. :)
I like it! I'll tell the missus its time to braai. She's the social manager
Has thanked: 1136 times
Been thanked: 1047 times
Florian320 wrote: 14 Jul 2022 12:26 I‘ll try to build something that I can put direct battery-power to the motor an see wether it is better then.
Florian
Florian, you don't need to build anything.
Take off the door card, un-plug the motor and using a piece of twin flex cord connect it directly to thd battery. Swopping polarity changes the direction.
Overambitious
Nickname: Conrad
Has thanked: 1 time
Where abouts are you based? If you're close to Randburg, you're welcome to come see me and I'll check what's wrong for you.
