Rear Sway bar links
Unkredible
Full Name: Bruce Williamson
Nickname: Unkredible
Home Town: Rivonia
Home Language: E
Has thanked: 27 times
Been thanked: 24 times
Rear Sway bar links
Post by Unkredible »
Hi All,
Does anyone know where I can get a set of standard rear sway bar links? Mine seem to have a lot of play on the ball joints, causing noise.
Maybe someone who has done a lift has their old ones lying around?
Bruce
285x75x16 MT
DC-DC Charger
Re: Rear Sway bar links
I may be wrong here, but the rear sway bar links don't have ball joints, they should all be rubber bushes. These are easily replaced ( well labour wise probably not, as they are pressed into the ends of the sway bar), but don't use the poly-something ones, as they deteriorate quickly with the amount of flex our Patrols have. Rubber ones are the way to go.
Has thanked: 1124 times
Been thanked: 1038 times
No, they do have ball joints on the ends of the arms.
I have seen some aftermarket jobs which have polyurethane replacing the ball joints, but they don't last anywhere near as well as the ball joints.
Have them as stock item from terrain taimer just measure and send dimensions
Ahhh... Learnt something new... :biggrin: :thumbup:
