engine replacement 4.2 TD GU Y61
Full Name: Kgothi
Nickname: Neo
Home Town: Gaborone
Current 4x4: GU Y61. 4.2 TD patrol Bakkie
Home Language: Setswana
Post by Cedric »
Good day
i have recently purchased a patrol bakkie 2008 model with engine TD42,Y61. THE CAR ENGINE COULD NOT TURN, WE OPENED THE HEAD AND FUND THAT THERE WAS TOO MUCH RUST, AND THE MECHANIC RULED THAT THE HEAD SINCE ITS CAST IRON, IS DEAD, AS SUCH RECOMMENDS NEW ENGINE, OR A NEW CYLINDER HEAD, THEN TO BUY THE WHOLE VALVE KIT, EXAUST AND INTAKE VALVES, THEN RE-SLEEVE THE BLOCK.
WHATS THE BEST OPTION YOU CAN ADVICE. THE ENGINE IS PRICEY, OR IF SOMEONE KNOWS WHERE I CAN SOURCE THE ENGINE PLEASE ASSIST. I AM IN BOTSWANA.
THANK YOU
Re: engine replacement 4.2 TD GU Y61
Oijjj Cedric, That is a bummer -
Michael can supply SA; Gauteng
David MIGHT have a used engine at his PATROL G Yard [Bela Bela]
They must get their prices to you
Then - There are many UD 40 Nissan Trucks in Botswana accident damaged but engin still fine [It is the same angine then that in Y60 and Y61]
yOU MIGHT ALS SEARCH FOR THE nissan fork lift
tHEY ALSO USE THE td42 ENGINE
Has thanked: 244 times
