Roof Racks
- kyzah
- Full Name: Charles Reddiar
- Nickname: Charles
- Home Town: Midrand
- Current 4x4: Nissan Safari Granroad 4.2D
- Has thanked: 11 times
- Been thanked: 8 times
Roof Racks
Hi guys.
Do roof racks have to be built for a specific vehicle like the GQ? Or can a generic rack (gutter mount) work. Takealot has quiet a few.
- Has thanked: 1124 times
- Been thanked: 1038 times
Re: Roof Racks
Most of the big-brand racks have adjustable feet, or one can purchase the feet separately (although often the cost of a set of feet exceeds the cost of a second-hand rack).
My Outback rack was originally made for a Disco 1/2, but I was able to modify the feet to work.
- Spike
- Full Name: Spike Pretorius
- Nickname: Spike
- Home Town: Milnerton
- Has thanked: 77 times
- Been thanked: 87 times
Re: Roof Racks
Try do some homework with measurements because if you have to mcguyver the brackets it can be quite a hassle, and if you need to replace brackets, as Peter says, it's not economically viable. Not just the length and width of the rack but also the height that the rack will sit above the roof. The last rack I bought I ended up having to do a lot of fabrication that in hindsight I should never have bothered with but I was committed and had to see it through to completion. Usually those brackets only have about 20mm-30mm max adjustment leeway in each direction (so 40mm-60mm width in total, and 20mm-30mm height)
Sardonic Fattist
- Witbobbejaan
- Full Name: Dion
- Nickname: D.
- Home Town: I dont know, name keeps changing...Eastern Cape
- Current 4x4: TB45
(Wife's TB42) - Home Language: Afrikaans
- Has thanked: 34 times
- Been thanked: 16 times
Re: Roof Racks
We have both a gq and gu.
The roof dimensions and slope arent exactly the same, so unless my measurements were off when I looked a few months back, then even between patrol models a straight fit is not guaranteed...so make sure your brackets are adjustable in height and width.
Re: Roof Racks
the ave Gu race fits on GQ it just needs to be adjusted a bit. I have one at my place if you want to fit
- kyzah
- Nickname: Charles
Re: Roof Racks
Thanks Tinus. I might take you up on that offer. I do have an old rack, used on previous SUV. I'll have to drag it out as see if its modifiable.Tinus lotz wrote: ↑27 Nov 2021 07:07 the ave Gu race fits on GQ it just needs to be adjusted a bit. I have one at my place if you want to fit
Re: Roof Racks
i have new brackets thats ajustable for a patrol roof rack if you need
Sent from my SM-N975F using Tapatalk
Re: Roof Racks
I have the roofrack from a LAND ROVER 110 S/W on my Patrol GQ, I wanted the extra length because I have the Bundutop Roof tent - No problems to fit it on the GQ AND the higher fot of the Landy rack gives that I could fit my ladder, a 50, liter water tenk and the table UNDER the roofrack
- kyzah
- Nickname: Charles
Re: Roof Racks
Interested in this. Let me get my rack out and check sizing. I'll msg you.Tinus lotz wrote: ↑01 Dec 2021 12:44 i have new brackets thats ajustable for a patrol roof rack if you need
