4500 GL - Sorting, Cleanup, Tips, Tricks, Info
petri oosthuizen
Full Name: oosthuizen
Nickname: petri
En Mamma se Kar, 'n Ford
Home Language: afrikaans
Has thanked: 46 times
Been thanked: 33 times
Post by petri oosthuizen »
Lots to do on this baby.......:
1) Check shocks/bushes, basically everything underneath..............................DONE
2) Roofrack would be nice. Black, low profile........................................... .DONE
3) Seat covers, maybe also other canvas sakkies en goedjies..........................As Above.
4) Clean up all little chips/marks etc etc..................................................As Above. Its almost December.
5) Rubber or similar mat at rear load area, for Dog and to mess in....................PRORITY
6) Powdercoat all those sexy steelies back to new again..................................PRIORITY
7) Tyres, a higher profile, not wider, maybe even narrower if possible................DONE
8) Chuck the CD shuttle thingie , new radio and speakers.................................ASAP
9) Maybe a drawer system............................................ ...............…........Later. But then where does that spoilt dog sits??
10) Rattle at the back.............................................. .............................PRIORITY
11) Very slight missfire, replace plugs, clean MAF, new Bosch fuel pump.........……….DONE
12) RWC, Registration...................................... ......................................DONE
13) Wiper Blades......……...…………………………...…...…………….........…….........………….DONE
14) Nissan Whee Nuts...……...…………...…...………...……………...…...…………...……………...DONE
15) Grease Props, joints, all Greasable Parts...…......…...............…….........………...DONE
16) New Radiator...………...………...…...……...……...……...…......…………......……...……….DONE
17) New bonnet Rubbers......…...………...…...……...……………...……………...…………………...DONE
18) Fix loose engine cover...…...…...…….........…...……...……...……...……………......……..DONE
19) New aircon bearings......…………...…………………………......………………………………...……...DONE
20)_Replace ALL belts......…………………......………...…….........…….........…….........……...DONE
13) Dual Battery System............................................ .................................DONE, portable battery box will work better
14) Check Radiator and ALL hoses, clamps etc etc, Sommer Net in case...............…...DONE
15) Just go and do trips with this Beauty............................................ ................PRIORITY!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
petri oosthuizen
Nickname: petri
Re: 4500 GL - Sorting, Cleanup, Tips, Tricks, Info
Guys
Want to start somewhere here, I think that slight missfire/hestitation would be a good place.
Thinking possible causes would be MAF, plugs,check leads, and fuel pump, sommer also fuel filter. Also clean the PCV Valve (thats the correct name I think?
Sommer want to do everything in one go, then I know its sorted.
1) I saw the Bosch fuel pump somewhere but cant remember. Which fuel pump/part number please??
Is it a difficult job to do, the fuel pump?
2) I'll do the MAF cleaning myself
3) Plugs?? NGK?? 1.1 mm gap??
I've heard its a job to get to the plug against the firewall, any tricks there?
4) I'll sort the "external" fuel filter underneath the car myself.
5) Sort that PCV Valve myself.
.............So its basically just that fuel pump Part number I need, I think it was a Bosch product.
THANKS
Anything else that could cause that hestitation??
NoPressure
Full Name: Ruan
Nickname: Ruan
Home Town: Swakopmund
Has thanked: 92 times
Been thanked: 58 times
Post by NoPressure »
I had mine replaced just last week when I sorted the timing. I will try and phone to get the part number. Otherwise, Marinus (Marino4x4) replaced his a while ago with an SD electrical one. He might have the part nr.
NoPressure
Full Name: Ruan
Nickname: Ruan
Ok, so I quickly phoned. Bosch part nr. S000TE12S9
I don't know SD electrical, would prefer a better known brand for this critical part.
I am sure it might also be somewhere on the serviceable items thread - otherwise someone could maybe update their TB45 list with this info?
:salute:
petri oosthuizen
Nickname: petri
Thanks a MILL.
Then.......what contact cleaner do I get to sprayclean that MAF sensor??
Ek moet dalk net eers 'n dubbeltjie vat en 'n Cameltjie rook voor die tyd................... :surprised: :lol:
The Wurth Maf cleaner has worked well for me.
Ja... en jy wil dalk nie naby daai good rook nie!!! :smokingjoint:
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Post by mvcoller »
Gaan koop 100ml Rubbing Alcohol by plaaslike apteek om MAF skoon te maak. Het my R32 gekos. Koop sommer klein 10ml inspuiting "syringe" en 'n naald om dit mee skoon te spuit.
Bosch agent het dit aan my voorgestel. Ek wou carb cleaner gebruik en hy het gesê ek moet dit NOOIT op die MAF moet gebruik nie.
petri oosthuizen
Nickname: petri
Where is this car's PCV Valve situated?? I want to clean that too.
Just blow-cleaned the MAF sensor with Spanjaard Elektro Kleen.
Idles smoother, pulls even smoother that before.
Still has that VERY slight "dead plug??" miss at idle, and it feels as if it can pull better under acceleration.
Also doing the plugs today, and replacefuel filter - sommer net sommer, dan weet ek dis gedoen.
And then the fuel pump, will either get the Bosch one or order one fron Graham Cummings, apparently he has the "correct" German one (prolly the Bosch??)
But - where's that PCV??
THANKS
JTEC
Full Name: Jade Dafel
Nickname: JTEC
Home Town: Somerset West
Has thanked: 164 times
Been thanked: 64 times
Post by JTEC »
petri oosthuizen wrote: 19 Nov 2019 11:13
Hi Petri
Regarding the missfire on idle. I had the same issue on my 4.8 which only got worse over time and it turned out to be one of the ignition coil packs. Not sure if the TB45 has an on plug type coil but worth checking out.
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
