Morning, has anybody done this?, the GQ has a useless bearing stopper/washer in place to keep bearing from moving sideways where the GU has a lockable system
Converting GQ bearing setup to GU system front axle
- Jules
- Full Name: Julius
- Nickname: Jules
- Current 4x4: Pathfinder
- Has thanked: 94 times
- Been thanked: 76 times
Re: Converting GQ bearing setup to GU system front axle
Ja ou baie manne het jy gooi net gu spares op piet weet wat alles moet gebeur
The incredible Mr. Connan...
- Has thanked: 1140 times
- Been thanked: 1050 times
Actually, I have never done it, but apparently Frans does it quite regularly.
I believe all you need are the two nuts and the little screws that lock them together.
I make improved tab washers instead, so that the standard nuts work better.
