DIY Low fuel warning light
EFH
Full Name: Elmar Henning
Nickname: EFH
Home Town: Bloemfontein
Current 4x4: 2000 Nissan Patrol 4.2 Turbo Diesel
Home Language: Afrikaans / English
Been thanked: 12 times
Post by EFH »
My 2000 4.2d only has the main tank, and being a GL I assume there is no low fuel warnig light. Would it be possible to install a diy warning light?
My 2000 4.2d het net die main tank, en siende dat dit 'n GL is, weet ek nie of hy een het nie. Sou ek een kon diy?
2000 Nissan Patrol 4.2 Turbo Diesel GL
Burnco Replacement Bumper, Suspension Lift, Terrain Taimer 'erd
Turbo Conversion by Sojo Automotive - Michael Steyn
Re: DIY Low fuel warning light
Jy kan as jy wil ja mens kan op die sender n micro switch mount
Anthony Forgey
Full Name: Anthony Forgey
Nickname: Anthony
Home Town: Randburg
Has thanked: 182 times
Been thanked: 206 times
Post by Anthony Forgey »
I have the '98 GL and it definitely has a fuel light.
EFH
Nickname: EFH
Post by EFH »
Thanks Tinus, ek sal bietjie op Google spring.
Anthony, if driven it to just under the empty line. Don't kniw if it only switches on then?
Pull out sender and move it to have a look
EFH
Nickname: EFH
Post by EFH »
Going to this week, doing some other maintenance
Yip, mine is also the GL, with only main tank. The needle has to drop to just on the "E" line before the orange light comes on..... I make big poo's when I see that light come on..... bleeding a 4.2 diesel if it runs out of diesel is not going to be fun, unless you have a lift pump fitted
Has thanked: 243 times
Been thanked: 208 times
Discovered that my gq got a low fuel warning light.... which does not work most of the time.
It appeared for the first time over the weekend. Next time i started the car it was gone.. :think:
SJC wrote: 26 Apr 2022 06:10 Discovered that my gq got a low fuel warning light.... which does not work most of the time.
The GU pumps fuel from the subtank to the main for a few seconds every time the vehicle is started. I believe this is part of its self-test procedure. If the GQ works the same way, it is possible that the fuel pumped into the main from the sub when the vehicle was started filled up the main enough for the light to disappear. Alternatively, it could also possibly be fuel draining back from the pipes when the vehicle was off which filled the main tank slightly.
That said, I'm too scared to wait for that fuel warning light to come on at any point in time. In the case of my vehicle and my experience, that light does not mean "warning: low fuel". It means "warning: I will do about another 500 metres before I die". In short: I try and refuel long before there is any possibility of that light coming on at all...
Has thanked: 1130 times
Been thanked: 1044 times
GQ's don't have sub-tanks (not factory ones anyway).
Never seen a low-fuel warning light in mine. Take a photo next time, so we can see where it is please Fanus?
