Technical advise hot dip galvanising
Rodney
Full Name: Rodney Smith
Nickname: Rodney
Home Town: Port Elizabeth
Current 4x4: 2013 3.0D GL
Been thanked: 10 times
Post by Rodney »
My troll was fitted with a genuine Nissan bullbar by the selling dealership prior to selling it to me.
After a little more than a year at the coast the powder coating is showing extensive signs of rust all over the entire unit. Clearly rusting under the powdercoat. My inclination is to galvanise. However I seem to recall reading somewhere that there is a danger of distortion during galvanising.Can anyone on the forum give me guidance here?
My steelies are also starting to show rust so they would go the same way.
Has thanked: 1136 times
Been thanked: 1047 times
Re: Technical advise hot dip galvanising
Hot-dip can cause warping, but I think the chances are relatively small. I have galvanised some fairly large structures (such as a trailer chassis, rock sliders and bash plates) without any problems.
However, paint and powder coating doesn't stick to galvanising very well. So unless you like a raw galvanised look this might not work as well as you hope.
Also, I don't think a tire will seat on a galvanized surface, as it is too rough?
I would recommend decent shot-blasting followed by a professionally-applied epoxy paint system.
Anthony Forgey
Full Name: Anthony Forgey
Nickname: Anthony
Home Town: Randburg
Has thanked: 181 times
Been thanked: 206 times
Post by Anthony Forgey »
You could also consider electro-galvanizing. I'm not sure how many electroplaters would have tanks large enough for a bullbar.
if you do galvanize, make sure to drill a hole on both sides of any tubing that is completely welded closed. it allows the zinc to go right inside and drain out, as well as preventing the tube from bursting in the hot tank.
As peter said, hot dip and paint are not friends. it can be done but if you electrogalvanise it wont be a problem.
juice
Full Name: greg justus
Nickname: juice
Home Town: benoni
Current 4x4: patrol 2001
safari 1984 wagon
safari 1982 wagon
Home Language: english
Has thanked: 1 time
Been thanked: 12 times
Post by juice »
You can powder coat hot dipped galvanising ' you need to tell the guys where you get it done not to passavate it ( so when you get it back it a dall colour and not shiny) the powder coating sits on the surface like no tomorrow, All clear view fencing is done like that
Electrogalv plating does not get into the inside of the pipes to stop them from rusting from the inside
Rodney
Nickname: Rodney
Post by Rodney »
Thank you for the feedback. I will tackle this after the easter period and let you know the outcomes.
SCUBA Patrol
Full Name: Phillip Jacobs
Nickname: Phillip
Has thanked: 31 times
Been thanked: 32 times
Post by SCUBA Patrol »
Galvanizing sort problems but there are cons to it.
1. weight, calculate the weight added to the bar before considering galvanizing (the galvanizer should be able to assist you here)
2. Drilling holes of suitable size into tubes at the correct positions are critical as holes in the incorrect position will add additional weight and cost! (you normal pay for the zinc after galvanizing). Drilling holes might damage the integrity of the bar, (my opinion)
I would rather get all the powder coating off, gritblast and paint with "Hammerite" paint. This is easily repairable, just give another coat of paint. Hammerite have both a smooth paint and a "hammerd" look that hides a lot of imperfections.
Phillip
2006 3l with MADMAN
