Knock sensor code 0325 and overfueling
biggles
Full Name: Steven
Nickname: Steve
Home Town: Durbanville
Current 4x4: GUII Patrol 4.8
Has thanked: 21 times
Post by biggles »
Hello All
On my recent Kaokoland trip I had the check engine light come on and had the codes read. it was 0325 Knock sensor.
I had it cleared and proceeded on for 400km before it reappeared.
I spoke to Tour de Frans and we agreed that is was a bad batch of fuel. I had 200l of the stuff but managed to swap it out for other petrol at a friendly station in Ruacana. Thinking we had the problem licked we proceeded into the nether. Anyway all was still not well and the car was overfueling and hesitating. There was nothing i could do at that point but proceed. To rule out fuel I ran the main tank to fumes and then filled up in Otjiwarongo with fuel from the busiest station and had the codes reset. All went well for 70km. When I started up the next day 1km down the road the light came on again and the engine was hesitating. I am back in Otjiwarongo and need to take the car back to RSA on the 20th.
So given all the different fuel I have had in it i would say it is not a fuel issue. It must be the knock sensor. Does anyone know where it is? How difficult is it to get at? Can I test it without getting to he sensor itself? I suspect that I will have to remove a lot of the chargecooler and inlet manifolds to get to the sensor. I am thinking if I can get to where the other end of the wires plug into the ECU I test the sensor without removing all the peripherals.
Ps I cannot reach frans.
Anyone know Nissan Windhoek? They seemed quite good when i went there to have the codes read.
:layrubber:
biggles
Full Name: Steven
Nickname: Steve
Re: Knock sensor code 0325 and overfueling
Post by biggles »
Anyone with the workshop manual?
:layrubber:
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 20 times
Been thanked: 97 times
Post by David M »
Hope this helps Steve.
roelf prinsloo
Full Name: Roelf Prinsloo
Nickname: Roelf
Home Town: Klerksdorp
Current 4x4: Nissan Patrol 5.6L V8 LE Premuim ( Y62 ) 2018
Has thanked: 17 times
Been thanked: 17 times
Post by roelf prinsloo »
You can try NAMIB DYNO in Swakopmund. Frans Bezuidenhout also knows a Patrol well.+264 64 401 148
Mystical_Beast
Full Name: Julian Hilder
Nickname: none
Home Town: Edenvale
2007 RRS 4.4 V8
2004 Colt Rodeo 3000
SIII Landy pick-up
Has thanked: 15 times
Been thanked: 18 times
Post by Mystical_Beast »
Hi Steve
I chatted to Steven Green and your theory is in fact correct.
It is over fueling because of the knock sensor and the fault is directly related to the sensor.
Knock sensor will severely retard timing.
According to Steven either electrical (BAD CONNECTION/FAULTY WIRING) or mechanical fault with the sensor itself.
biggles
Full Name: Steven
Nickname: Steve
Post by biggles »
So patrol is sorted and I am fuming... seriously pissed off.
The cause of the missing was two loose coils packs, missing screws and plugs loose. When the patrol was services before the trip I had the sparkplugs replaced. The @#@!$# that did the job must have not put the plugs from the coils back correctly. So it went in to Nissan for the first time (and i am talking a 600km drive) and they found the one coil. Then is started again after about 50km but I was already back on my way to otjiwarongo. So a second visit to Nissan they located the second loose coil. Now everything is 100%. And the guy that did the plugs is not answering the phone.
I also the same guy do the brake pads and disks before the trip... this is what i found underneath when I was looking for loose wires to the knock sensor...
That is a missing bolt on the brake caliper :thumbdown: I hesitate to think what would have happened if that had come adrift going down Hex Pass with the caravan hooked up as i did last week. I cannot image without getting shivers.
:layrubber:
That is very SAD!!!
I hope none of our members use this Muppet!
Those issues are life & death on the trail...
:imsorry:
Has thanked: 1134 times
Been thanked: 1044 times
Jeepers!
Users browsing this forum: Google [Bot] and 2 guests
