30L Ozzie Water Bladder for Sale
CarloG
Full Name: Carlo Gonzaga
Nickname: Carlog
Home Town: Johannesburg/Midrand
Current 4x4: Nissan Patrol 4.8GRX 2005
Nissan Patrol 4.8 GRX 2010 (Retired)
Hyuandai Terracan 3.6L (Retired)
Home Language: Engels
Has thanked: 7 times
Been thanked: 12 times
Post by CarloG »
Hi chaps - i bought this water bladder from Australia and got ready to install it today only to discover that it will not fit the GRX as it has the aircon unit in the rear left of the boot. Its a 30L bladder that hangs inside the rear left panelling so its really just unused space.
I paid $240 dollars for it plus some shipping VAT and customs. Any offers above from anyone on buying this from me?
Link to the seller in Australia https://www.ebay.com.au/itm/NISSAN-GU-P ... 2749.l2649
Description from the website:
FlexiMake 30 Ltrs Drinking water bladder tank NISSAN GU Patrol (2004-2016) for 4x4 and Camping
We offer a fantastic range of water bladders.
This bladder tank is made in Australia from a superior reinforced PVC material which offers portable drinking water storage to Australian Standards.
We use the finest 100% Australian made PVC fabric (900gsm) for our potable product range.
Specifications are as follows:
Material: 900GSM Food Grade Reinforced PVC, 2 year warranty, 900GSM, dark grey colour.
Standard Fittings: 1x 13mm Skin fittings and cap (Breather)/ 1x 13mm Skin fittings and hose kit (Inlet/Outlet)
Own a Landcruiser or a Patrol? When camping, ever think to yourself “My Cargo area is so full, but I need some extra water storage, what can I do?”
Wonder no more, Fleximake has the perfect solution for you and your water storage woes.
We have designed a perfect bladder to fit inside the rear quarter panel of the NISSAN GU Patrol (2004-2016). This bladder takes on the standard design of our hanging bladders, but is manufactured to the shape to fit the empty space on the passenger side comfortably and snuggly, it connects up to existing threaded holes inside the rear quarter panel using included nuts and bolts and once connected the plastic shroud can be placed back onto the panel. Fittings can be plumbed through existing openings within the shroud or can be custom plumbed at specific points you require. This hidden bladder is able to hold an approximate capacity of 40 Litres, perfect when you need a quick drink when out bush, or to hold you up before the next water refill.
Standard fittings that come with this bladder are 2x ½” BSP Threaded Fitting with Tap/Valve Hose Kit and a Breather Hose Kit. These hose kits can be plumbed directly into the plastic cover, or the hoses routed into existing holes in the plastic cover.
As standard with all our 4WD Water bladders, these are manufactured using a strong AUSTRALIAN MADE, DRINKING WATER GRADE (AS 4020 Certified) PVC Material and comes with a 2 Year Warranty. All parts of this bladder (including fittings/hoses etc) are all sourced in Australia and entire manufacturing process is done right here in our factory in South East Melbou
'05 Patrol 4.8L GRX
'13 Conqueror Companion
Specialsied Stumpjumper. Munga Trainee
JHB to London '07, 16000km, 39 days, by Bike
90days camping - JHB to Nairobi and back - 2014
"We travel not to escape life but for life not to escape us"
pgreeff
Full Name: Paul Greeff
Nickname: Paul
Has thanked: 24 times
Been thanked: 56 times
Re: 30L Ozzie Water Bladder for Sale
Post by pgreeff »
What a great idea!
2004 Nissan Patrol 4.8
CarloG
Nickname: Carlog
Post by CarloG »
Even better if you make me an offer :blonde:
'05 Patrol 4.8L GRX
CarloG
Nickname: Carlog
Post by CarloG »
Any takers?
'05 Patrol 4.8L GRX
