2007 Nissan Patrol 4.8 GRX Timing Chain Replacement
- Newbie
- Full Name: Stefan Olivier
- Nickname: Stefan
- Home Town: Secunda
- Current 4x4: 2007 Nissan Patrol 4.8 GRX
Good day to all.
I cannot find any reference to the replacement schedule for the timing chain on my 2007 Nissan Patrol 4.8 GRX; I have tried to find information on this forum as well as the workshop manuals to no avail.
Does anyone perhaps have any more knowledge regarding the maintenance requirements for the TB48DE timing chain?
Thanks in advance for your assistance.
Stefan Olivier
Stefan Olivier
- Has thanked: 1124 times
- Been thanked: 1038 times
Re: 2007 Nissan Patrol 4.8 GRX Timing Chain Replacement
I don't think it's a service part? IE, I don't think it will need looking at before your first engine rebuild?
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
- Been thanked: 92 times
Why do you want to replace that chain...????
- Newbie
- Nickname: Stefan
Thanks for the speedy reply gentlemen. I don't really want to replace the timing chain if it's not required, but I also don't want to find out I should have replaced it after the engine blows up... I work in the mechanical maintenance environment and have come to realize that prevention is better than cure.
Since the weather has turned a bit colder, my vehicle has started making a rattling sound upon start-up which then proceeds to go away after a minute or two of driving. I suspected that the timing chain might be at fault hence my question regarding the replacement.
Do any of you perhaps have any thoughts regarding this rattling sound when starting the engine cold?
For reference, I recently replaced all of the drive belts at the front of the engine, as well as the engine oil with 5W40 Castrol Magnatec.
Stefan Olivier
Stefan Olivier
Sounds like the tensioner rather than the chain itself?
And since that is oil-pressure driven, I think the problem is related to the oil or the oil pressure.
Did it ever make the noise before the oil change? If not, perhaps it doesn't like the Magnatec? Alternatively, perhaps there is a bit of sludge somewhere? In the old days, Castrol was known for sludge build-up, but I ran Magnatec in a couple of cars and never had any issues myself.
- Nickname: Wilkie
this is my opinion on that Castrol oil you using...I will not touch it ..!!!!!Stefan_Olivier wrote: ↑02 Jul 2018 08:28 Thanks for the speedy reply gentlemen. I don't really want to replace the timing chain if it's not required, but I also don't want to find out I should have replaced it after the engine blows up... I work in the mechanical maintenance environment and have come to realize that prevention is better than cure.
Stefan Olivier
- Full Name: Andries
- Nickname: None
- Home Town: Pretoorsdorp
- Has thanked: 28 times
- Been thanked: 38 times
Could the noise be the tappets? I know on my 4.8 when I start it for short periods. I .e. get home park car outside and only later the day park it in the garage , i.e. very short start , park in garage and switch off then from time to time the next start up will have the noise. Started happening after I started using Magnetec (and had a hell of a fright the first time), I'm using Helix now and can't recall it happening recently. 260k on the engine
- Chris Skinner
- Full Name: Chris Skinner
- Nickname: Chris
- Has thanked: 10 times
- Been thanked: 53 times
Strange.. Ive been using the Magnatec for quite a few years now and never had any such problems.
- Nickname: Wilkie
Chris jare terug toe motorsport nog groot was in SA was n klient deur Castrol geborg gewees en ons het baie probleme opgetel met enjins ,veral met daai clatter met die op start in die oggende ,veral met dubbele bo nok asteChris Skinner wrote: ↑03 Jul 2018 18:32 Strange.. Ive been using the Magnatec for quite a few years now and never had any such problems.![]()
Ons het later maar Shell of Mobil in die Castrol houers gegooi om die Borge gelukkig te hou....
Die olie het seker verbeter maar n ou hond bly maar n ou hond en ek sal dit nie sommer weer gebruik nie
- Newbie
- Nickname: Stefan
Thanks for all the replies guys; much appreciated.
I have used Castrol Magnatec for some time in my vehicles now and this is the first issue that I have picked up. If this is a known issue, which oil is preferred for the TB48DE engine?
The rattling noise appears to be coming from the engine valve cover; could it be that the oil is quite thin and drains off the valve lifters?
I tried to illustrate the problem to a family member at an ambient temperature of about 20 degrees celsius and the problem was not present. The issue only occurs during very cold mornings (i.e. ambient temperatures of around zero to 10 celsius).
Stefan Olivier
Stefan Olivier
