2 Issues i need help with.
- Russ Kellermann
- Has thanked: 8 times
Hi guys.
1) My front park lights are not working.... where would i look to find the fuse for this?
2) My back-light illumination on the dash are not working (just the fan speed ones , so basically ,half the cluster).... were would i look to find the fuse for this?
Best
Russ.
Best
Russ.
- David M
- Full Name: David Marais
- Nickname: David Marais
- Home Town: Midrand
- Has thanked: 20 times
- Been thanked: 97 times
Re: 2 Issues i need help with.
1 - In the fuse box under the bonnet - labels are under the coverRuss Kellermann wrote:Hi guys.
Best
Russ.
2 - In the fuse box in dash - will be labelled "illum" or "aux" or anything other than what it is..... easiest is to use a test light on each side of the top of the fuses and see which is blown..... put lights on before testing....
- Been thanked: 430 times
Russ, maybe have a look at the front park lamp globes as well. They are those push in ones and tend to die very easy and have replaced mine more than once already.
- David M
Yep they die quite often. Replaced mine with LED's 3 years ago and no more problems.Michael wrote:Russ, maybe have a look at the front park lamp globes as well. They are those push in ones and tend to die very easy and have replaced mine more than once already.
- Russ Kellermann
Thanks guys
Ok awesome. I'll look at this this morning.
I thought it may be globes too, as i've had to replace one or two of them over the years.... but, with both going out at the same time it seemed unlikely. But i'll check.
I don't have a test light. .... perhaps something i need to invest in?
Russ, A multimeter will also work. Set it to Ohms and place each end of the probes on each end of the little piece of metal that is exposed on the top of the fuse. If it shows a "0" value then the fuse is still good. If it shows a "1" then you need to replace the fuse. Lights don't have to be on for this method. Its easier than pulling out each fuse one at a time and messing up the radio settings and clock time etc
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
- Been thanked: 92 times
Russ if you turn your park lights on do the tail lights come on..and if they do than you don't have a fuse problem but blown park light globes..goodluck
Russ...
You need a turbo on that truck.....then all the problems will dissappear
- Has thanked: 1124 times
- Been thanked: 1038 times
I would be very surprised if either of these problems are caused by a blown fuse. I just can't see that either the front park lights or half the instrument cluster would be seperately fused.
- Russ Kellermann
Ok so....
1: front park light bulbs both burnt. so i'll get two new ones. BUT!.... front left wiring right near the bulb holder has been chewed by a mouse or rat ! Cant believe it but no other explanation.
Do you think i can get one of those bulb holders from Midas?... unfortunately the rat chewed it right up against the holder, so cant use the original one again.
1: All fuses for dash lighting fine... so i need to get to the " backlight" bulb behind the Dash panel ( only the fan speed adjuster light bulb seems to be out).
Its a 2007 GU Pickup, ... so its the old fashioned type front panel. Any one know the safest way to get it off without gouging the panel?
