Terrain Tamer Suspensions
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 17 times
Been thanked: 87 times
Post by Marino4x4 »
Good day
We are looking at importing Terrain Tamer Suspensions. They use a system called Smart Coils. The coils has a variable diameter to ensure a soft ride when there is no load in/on the vehicle, but as soon as the vehicle is loaded it will stiffen up due to the thicker coils in the center of the coil.
Please have a look at this video:
Smart Coils Explained
The suspension kit includes the caster correction bushes, shocks, coils and steering damper.
We can make these kits available without fitment at:
R18 800 for the standard suspension (GQ, GU Wagon)
R33 100 for the Pro Suspension (GQ, GU Wagon, Not available for 4.8)
R28 600 for the standard suspension (GU Bakkie, 4.2 and 3.0)
We can get kits for the Safari also, please contact me if you are interested. This is model specific. The cost will be R25 700 - R28 400
You can reply to this thread and if there is enough interest we can arrange a shipment.
All orders will have a 75% deposit with order and full payment before delivery. Delivery is also only to major centers. Please contact for shipment quote if you do not live in one of the major centers.
Cheers :thumbup:
Marinus
Terrain 4X4 Parts
Patrol 4.5 GL 1998
Terrain 4X4 Parts
TijmenvdS
Nickname: Tijmen
Chevrolet 1974 K10 402 V8
Has thanked: 32 times
Been thanked: 106 times
Re: Terrain Tamer Suspensions
Post by TijmenvdS »
Sounds Awesome.
What lift does this kit offer?
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 »
Sorry, it is a 2 inch lift.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Nice ek hou nogal van die progressive coil idee...kom dir op al die models ....? En is daar n 3 duim beskikbaar :thumbup:
Has thanked: 1135 times
Been thanked: 1044 times
Ek het progressiewe coils agter op my kar (maak onbekend). Dis egter die goedkoper ontwerp, waar die draad se dikte konstant is, en die "pitch" van die coils verskil.
Dit is steeds die gemaklikste Patrol waarin ek nog gery het.
Het jy enige inligting MBT die lengtes van die skokbrekers (ingedruk en uitgetrek)?
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 »
Progressive coil is op al die coil spring modelle. Ongelukkig is dit net 2", niks hoer nie.
Peter ek sal vir jou probeer uitvind van die shocks se lengtes. Laat weet as ek die inligting het. :thumbup:
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Dit klink baie goed veral die 18k een sluit dit ook damper ccorrecttion ect in?
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 »
Hi Tinus
Ja, dit is die koste vir die hele kit.
Soos genoem, dit sluit caster correction bushes, coils,shocks en steering damper in.
Sluit alles behalwe instilasie in.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Is daar niks vir die 4.8??
Sover ek verstaan pas gq op gu en ek het al persoonlik gu y61 coils en shocks van van n nuwe 4.8 in n gq y60 gepas so ek glo nie dis n probleem nie :mytwocents:
