Front shock absorber
Has thanked: 1134 times
Been thanked: 1044 times
Has anyone got a front shock absorber i can borrow for a month or so?
One of mine popped a seal, and i am using the opportunity to get a set made up that can actually handle the extra flex of the Xlink, but it is taking a little longer than i had hoped, and since i need to to use the car daily rhe current situation is not ideal.
It can be anything as long as it fits and still works reasonably.
Has thanked: 61 times
Been thanked: 258 times
Re: Front shock absorber
Peter
Skakel my.
Ek het my voorstes uit gehaal (2" OME) omdat ek langer shocks in gesit het met spacers.
Ek wil hulle egter nog hou vir spaar. So kan hulle tydelik vir jou leen
Picasso
Full Name: HS
Nickname: Picasso
Current 4x4: Nissan Patrol
T3 Syncro
Home Language: German
Has thanked: 10 times
Been thanked: 45 times
Post by Picasso »
Hallo Peter
I dont want to compete with Alex...... he has got "first option".
If it should however not work out than I would have a used set of OEM (Nissan) shocks. which you could have and keep.
:salute:
Thank you gentlemen.
Henning, since the other three shocks on my car OME, i think it's better if i get Alex's.
Picasso
Full Name: HS
Nickname: Picasso
T3 Syncro
Post by Picasso »
Obviousely... that makes sense. :thumbup:
no problem :salute:
