Noise in rear axle
Dustin
Full Name: Dustin Roberts
Nickname: Dustin
Home Town: Port Elizabeth
Current 4x4: Patrol-less :-(
Has thanked: 42 times
Been thanked: 59 times
Noise in rear axle
Post by Dustin »
Hi all
I seem to be hearing a "kluk, kluk" noise coming from the right rear wheel ever so often.
It mainly happens on with a bit of steering turn and moving over uneven ground or going off of a kerb.
Can't be diff backlash, because it's only on the 1 wheel.
If I stand on the wheel and rock it side to side I can hear it sometimes.
Not sure if it is something or it's just my OCD doing it's thing.
Any thoughts ?
a.k.a. Datsun Dustin
GO PATROL !!!
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Re: Noise in rear axle
Post by Wilkie »
Dustin I had it that the caliper nut came loose and every now and then I heard this clak clak....
Maybe just jack the vehicle up and check those nuts and same time check wheel bearing play specially in out movement :salute:
Also check if your sway bar connects are not shot, they can make some noise when they are worn out
My anti roll bar was broken where the 2 connect and that made a noise everytime it bumped
Dustin
Nickname: Dustin
Post by Dustin »
Thanks guys :thumbup:
I'll check it out and report back :salute:
GO PATROL !!!
Dustin
Nickname: Dustin
Post by Dustin »
Had a quick look at lunch.
It was the sway bar nuts at the chassis mount. Was loosened.
All sorted.
Thanks again :thumbup:
GO PATROL !!!
Wilkie
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
that's what you call a "Quick Fix"
Lot of helpful and clever people on this Forum :thumbup: :thumbup: :thumbup:
Dustin
Nickname: Dustin
Post by Dustin »
Agreed !
Awesome bunch of guys here.
What irritated me to no end is I looked and didn't see anything initially until it was mentioned here :redface:
Oh well, you live and learn I suppose :biggrin:
GO PATROL !!!
