Rims (and tires) wanted
Has thanked: 1124 times
Been thanked: 1038 times
After having promised never to tow a trailer on holiday again, I am now building my own camping trailer...
But I have a small conundrum. The hubs I am using are from the current-generation VW polo (5 holes M14 x 1.5 on a 100mm pcd).
The original intention was to use the same rims and tires as on my Patrol (A-Line Grip 15" x 8" with 32x11.5 x15s). But the M14 x 1.5 capscrews I would need to bolt the adapter plate to the hub will set me back R900 for a set of ten, which seems a bit mad.
So I am investigating options. The question is whether I can find three Polo rims of abovementioned size (or maybe 15 x 7) for less than two Patrol rims and the cost of the adapter plates...
Anybody perhaps have some lying around?
Been thanked: 430 times
Re: Rims (and tires) wanted
Peter, there are some Polo and Golf wheels for sale on Gumtree if you are willing to fork out 2k for a set. They come with tyres so its not that bad really plus you will have two spare wheels as well.
http://www.gumtree.co.za/a-car-tyres-ri ... 0449210809
http://www.gumtree.co.za/a-car-tyres-ri ... 0850654309
roelf prinsloo
Full Name: Roelf Prinsloo
Nickname: Roelf
Home Town: Klerksdorp
Current 4x4: Nissan Patrol 5.6L V8 LE Premuim ( Y62 ) 2018
Has thanked: 17 times
Been thanked: 17 times
Post by roelf prinsloo »
By BOLTWORLD kos n as wat 1.6 ton kan dra van 2m lank 6 gat [ enige bakkie rim en patrol pas ook ] + - R 3500 .00 met remme en R1800.00 sonder remme.Dalk n opsie ?
Roelf Piet se wa het remme ma ry op air springs en hy het nie n formele as nie ..... :thumbup:
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Post by JoshJ »
Piet, ek het vir jou 19" met tyres. Nog soos nuut
Being alive is a Blessing!!
Joshua
JoshJ wrote:Piet, ek het vir jou 19" met tyres. Nog soos nuut
he he Pimp my trailer :thumbup:
Haijj daa Piet'a .. Wat van 16" PRO WHITE rims ? Meeste Bos waens kom met dit uit [gewoonlik 15"] maar 16 behoort ook op Gomboom rond te lê ...
en daar is in ons Uitreik stoor [16"] .. net eers sien wat gebeur met iNyathi se wiele .. of hy ook 17" gaan ry soos LOBO [OF lobo moet afkom 16" toe ???]
Hierdie add op Gomboom klink goed ??? http://www.gumtree.co.za/a-car-tyres-ri ... 0770753509
Thanks guys
Roelf, my trailer has independent suspension.
Josh, nee. Dankie, maar steeds nee.
Oom Mac, as daar pro-whites was in 100mm 5-gat, sou dit 'n opsie wees. Daai op die advertensie sou presies gewees het wat ek soek as hulle net 15" in plaas van 16" was. Dis vir my ononderhandelbaar: ek moet bande tussen die wa en die kar kan rondskuif.
JoshJ
Nickname: Joshua
Post by JoshJ »
Aggg ok Piet, try ok ma net help :lol:
Joshua
