ZD30 MAF
ZD30 MAF
Gents, I am looking for a ZD30 MAF sensor to borrow or buy.
Must be the 6 pin one, the first gen ZD30's had a 5 pin one so I need the GEN 4 sensor I think.
I have a 3.0 Patrol with a faulty one. I just want to put a working one in and make sure that it is busted before I go and buy one as they are quite pricy.....
Has thanked: 193 times
Been thanked: 275 times
Re: ZD30 MAF
Michael wrote:I have a 3.0 Patrol with a faulty one.
:surprised:
I thought you had/have a 4.2 :oldtimer:
Have you been pulling the wool over our eyes all this time WWW
Re: ZD30 MAF
Dirk, lyk my jy het weer niks om te doen vandag nie :oldtimer:
Ok I have a Patrol standing at my house...... better?
Will throw in a case of bear if someone can help with the swop test :thumbup:
Re: ZD30 MAF
QQQ
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Re: ZD30 MAF
Post by JoshJ »
Broer ek dink jy gaan sukkel met die ene. Daai MAF's is so brittle. Meeste van ons is te bang om na dit te kyk. Wat staan nog uithaal. As daai volts nie reg is nie, soos jy gemeet het, dan is hy sekerlik in sy kanon. Kon jy al n masjien op kry?
Being alive is a Blessing!!
Joshua
Re: ZD30 MAF
Ok interesting find is that the MAF that I have is also a 5pin one part number 22680 7S000 and looks like the ZD30's we heve here all takes the same.......
Re: ZD30 MAF
MICHAEL : I have a spare one lying her somewhere off AGAROB [3,0 Patrol 2001 model]
BUT if you do need to buy one .. go to the Nissan Parts counter yourself .. then make sure you are quoted for the SENSOR only [R1 600] and NOT THE ENTIRE MAF Housing [R7,000 ++]
I am in Benoni [and NO guarantee that this one is working .. it served as "spare" for AGAROB & BOEZMAN ]
Re: ZD30 MAF
Dankie oom Mac
The sensor itself is now over R4,000 from nissan and almost R10,000 for the sensor and housing.
Got one from a place in Cape Town new for R2,000 delivered......
Dis jammer oom se my nou van die spaar een wat by jou huis le, het vanoggend die een van die kaap af bestel
JoshJ
Nickname: Joshua
Re: ZD30 MAF
Post by JoshJ »
Bly jy het reg gekom vir so cheap. :salute:
Oom Mac, stof daai ene af en berre hom, iemand gaan hom nodig kry...
Joshua
Re: ZD30 MAF
Thnx Joshua .. hy is gebere .. ek soek nog steeds 'n ROOI GQ maar sal ook kyk na n 3.0 Di Patrol Y60/1
Michael, sorry, ek was verrre weg en het geantwoord toe ek jou post sien.
