Hanbrake cable removal
- Has thanked: 1124 times
- Been thanked: 1038 times
Does anyone know if it's possible to remove the handbrake cable without dismantling the drum and thus without unbolting the propshaft?
- Full Name: Martin Koorts
- Nickname: Martin
- Has thanked: 5 times
- Been thanked: 15 times
Re: Hanbrake cable removal
Op my 4.5 grx 2000 model kon ek nie, moes die propshat afhaal, nie seker van jou model nie maar ek dink dit gaan dieselfde wees.
- Been thanked: 430 times
Ek dink ook nie dit is moontlik nie omdat die kabel op die briek skoen arm in haak wat binne die drom sit.......sorry, maar ek dink jy gaan maar moet strip
Yeah .... ditto on what Micheal has said. I had a to do some maintenance in there and had to remove the prop bolts and then the brake drum to get in there. It wasn't a difficult job to do. I still pulled the patrol up on ramps so I could sit under there instead of lying down. You get better leverage on those prop bolts.... unless you have an air impact wrench
Hey Peter.... being on the bottom/underneath is also fun......
Its just the fiddling with the nuts that's a bit of a worry to me.....hahahaha.... Good luck bud !!
Cedric, at least one of us has a dirty mind. Probably, at least one of us also has dirty hands.
Ok ok ok..... I'll be the one with the dirty hands....
