Rear prop shaft 4.8 GRX
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Has thanked: 51 times
Been thanked: 10 times
Post by NMAD »
Can anyone confirm the correct orientation of the rear prop shaft by checking on your 4.8 GRX auto?
I have checked the Nissan part diagram and it shows the sliding sleeve or part with the rubber is closest to the rear diff. I also called Nissan and the parts guy confirmed its correct.
Reason I am asking is that I had my prop shaft balanced and the prop shaft fitment guy said it should have the sliding part on the gearbox/transfer side? :think:
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Re: Rear prop shaft 4.8 GRX
Post by Wilkie »
hi Noel the sliding Yoke is definitely closer to the rear axle ....... :salute:
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Post by NMAD »
Wilkie wrote:hi Noel the sliding Yoke is definitely closer to the rear axle ....... :salute:
Ok thanks Wilkie, I thought it was right but just needed to make sure as the fitment guy could not believe it went in that way round.
:biggrin:
Wilkie
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
Happiness :blonde: :blonde:
IanT
Full Name: Ian Temperley
2008 4.8 GRX Umkombe
Post by IanT »
Ditto Rear Axel :thumbup:
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Post by NMAD »
Out of interest is the front prop placed the same way? sliding yoke nearest to the front diff.......
Has thanked: 1135 times
Been thanked: 1044 times
On my car, both are fitted with the slip-joint nearest the gearbox. But mine's a GQ, so it probably doesn't count.
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Post by NMAD »
Hi Peter
I checked your Patrol on the parts catalogue and it also shows the propshaft slip joints nearest to the diffs? Maybe the SA version is different to the Euro spected patrols.
http://nissan4u.com/parts/patrol_gr/er_ ... ler_shaft/
Brett Bignoux
Full Name: Brett Bignoux
Nickname: Brett Bignoux
Home Town: Heatonville
Current 4x4: Datsun Safari Pick Up 1982 , Nissan Ruff , Yamaha Wolverine . Datsun Safari Wagon 1982
Been thanked: 9 times
Post by Brett Bignoux »
GOOD DAY GENTS !
On most serious 4x4's the slip joints are placed near the gearbox , to avoid damage from rocks , and there is less chance of being submerged during water crossings . Just some usable info for thought !
Cheers for now .
andredurand
Full Name: andre durand
Nickname: leeuloop
Current 4x4: PATHFINDER
Home Language: afr
Been thanked: 37 times
Post by andredurand »
Ek stem nie saam nie die slip joint moet nader aan die Ratkas wees ,Anders is daar te veel spanning op die propshaft Dit is my opinie kan verkeerd wees
Andre Durand
Nissan Hardbody 3.3 sold
Nissan patrol 4.5 sold
Nissan parthfinder 2,5 sold
Nissan navara 4l v6 4x4
