Will this diff lock fit?
Johann 1984
Full Name: Johann van der Spuy
Nickname: Johann 1984
Home Town: Kimberley
Current 4x4: 2013 Nissan Patrol 3.0 Tdi
Post by Johann 1984 »
Hi Guys,
Will a 33 spline H233B ARB Airlocker fit the front axle of a Patrol GL?
Thanks!
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Re: Will this diff lock fit?
Post by JoshJ »
This is only my opinion, but a front diff-lock on a Patrol is a waist of money. Their was a cruiser on the river trip and I can now understand why Toyota fit them with these. they have NO wheel travel. On the first big obstacle the patrols cruised through as where this gentleman had his wheels in the air and was relying on his front locker. A Patrol has so much wheel articulation that even the rear locker is very seldom needed.
rather use the money for a trip somewhere or something else on you Patrol. :mytwocents:
Being alive is a Blessing!!
Joshua
Has thanked: 1135 times
Been thanked: 1044 times
Josh, remember that traction is not always lost due to a lack of articulation. Mud and so forth, articulation doesn't help.
Sorry Johann, I don't know the spline count but I think that is correct (I think the smaller cars have 31-tooth splines). Perhaps phone Graham?
Iam not sure what diffs you are running but if you wanna do big trails a front locker is a plus point .....dont really need it every day but if you do its a nice to have :mytwocents:
I personally dont think a front locker is something I would spend money on at this stage. So far I have taken on every obsticle that came over my way and managed to do them all without allot of drama. If I had bought my Patrol with a front locker I would obviously have been very happy as it does come in very handy when you do need it.
Sorry if that didn't contrebute to your actual question, but found this on the ARB website. Seems like it should use a 31 spline locker. Think the one you are refering to might be one for a Hardbody.
YEAR AXLE DESCRIPTION SHAFT SPLINE RATIO PART NO.
1998 ON FRONT H233B 32 (1.26") 31 ALL RD136
Johann 1984
Eish... 4x4 MW had a clearance sale on ARB Airlockers. There's none left. They were selling at R6500 per unit without the compressor and fitment. That would've been a score...
Has thanked: 244 times
JoshJ wrote:This is only my opinion, but a front diff-lock on a Patrol is a waist of money. Their was a cruiser on the river trip and I can now understand why Toyota fit them with these. they have NO wheel travel. On the first big obstacle the patrols cruised through as where this gentleman had his wheels in the air and was relying on his front locker. A Patrol has so much wheel articulation that even the rear locker is very seldom needed.
Out of interest sake, did anyone see how much my pickup's wheels lifted compared to the cruiser's? (I have no idea).
I have also considered getting a front locker maybe in the (distant) future. There was definitely obstacles where I had to gain some momentum in order to get over. And too much momentum on rocky terrain can be quite damaging to a vehicle.
(I only got the LSD in the rear - which I'm not 100% convinced that it is working the way it should)..
Fanus, about 1/4 as much. Despite you having much less load on.
You do realize that you can tighten that rear LSD up significantly for almost no cost don't you? This would definitely by my first move if I was in your shoes.
Peter Connan wrote:Fanus, about 1/4 as much. Despite you having much less load on.
No, I didn't realise it. Thanks, I will look into this first.
Maybe then I wont need a front locker. :thumbup:
davidvdm
Full Name: David vd Merwe
Nickname: David - Hillbilly
Home Town: West Coast
Been thanked: 48 times
Post by davidvdm »
Peter, are you talking about these http://www.roadrunneroffroad.com.au/Nis ... -07mm.html
I have a H260 I'm fitting to the Sani. I need to strip to see what it looks like inside and replace the input bearing and seal as it is leaking. It seems to be LSD as my mate and I can not get the wheels to move independently from each other on the bench (I have not had it in the car yet). Our mechanic told us that he has seen the Patrols with LSD's so tight that this seems to be normal behavior. I am just worried that the farmer who had this diff before me has welded it :surprised: .
Now the question is, will the additional friction plates not make the diff to stiff for road use? Then, the only locker I seem to find available for the H260, is the ARB unit, or am I not looking hard enough.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
