1999Nissan Patrol GRX 4500 Air cleaner piping
Roger Craps
Full Name: Roger Craps
Nickname: Roger
Home Town: Kempton Park,temporary in Dakar(Senegal)
Current 4x4: 1999 Nissan Patrol 4500 GRX
Has thanked: 1 time
Post by Roger Craps »
Hi there,I wonder if someone could help me.
Between the Air Cleaner and the engine(on the 4500 Y61 engine) there's a small rubber konsertina piece with a metal hose clamp on each side that connect the air cleaner piping/ducting to the engine.
The one on my Patrol was for some reason badly perished.
I'v been to Nissan,it does not show on the parts catalogue,only the rest of the ducts and air cleaner components.
A while ago when I took my Patrol to Ben(from BG Auto fit) to fit Rock Sliders he gave me a piece of blue silicon pipe to fit,but I am worried the day I will do a lot of gravel roads driving that it may come loose and let dust into the engine with catastrophic results.
When I took my Patrol to Graham Cumming(GTech Motors) for oil replacement of all the gearboxes and diffs,he also could not help me.
Ek sal enige feedback baie waardeer.
Dankie.
Roger
Re: 1999Nissan Patrol GRX 4500 Air cleaner piping
Hi Roger, kan jy vir ons 'n foto op sit dat ons jou probleem kan sien.
Has thanked: 198 times
Been thanked: 275 times
I also need a replacement of this as mine is currently duct-taped ...... :redface:
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
Roger is that pipe before or after the airmass flow meter? Maybe send pic's,
I have also duct tape mine before the airmass flow meter,and that small piece of pipe comes complete with the airpipe connecting to the throttle body as a unit
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 20 times
Been thanked: 97 times
Post by David M »
Original parts from air filter housing to intake manifold
David M
Home Town: Midrand
Post by David M »
Heading towards intake manifold
Part 2
Part 2
David M
Home Town: Midrand
Post by David M »
Attachment to intake manifold
Part 3
Part 3
David M
Home Town: Midrand
Post by David M »
When replacing the filter element you need to disconnect at intake manifold (plus the other 2 pipes) and after air filter housing. Disconnect sensor, remove 2 butterfly nuts either side of housing and remove complete assembly.
Most mechanics sukkel by disconnecting the other connections and land up breaking parts and duct taping or siliconing together.
If you are battling for parts speak to Shaun Biddassee at Mark White Nissan. There is no part that he has ever not been able to get for me including obscure clips, trim etc etc.
Just be careful as if you order a part the assumption is that you get the plastic clip or rubber seal with it...... no...... separate part which must be ordered separately.
Best is to check that he is in, go and see him with your VIN no, look at the pics with him and order. Most of the stuff is ex Japan and you will be quoted 21 working days but normally arrives in 5 to 10.
Roger Craps
Nickname: Roger
Has thanked: 1 time
Thanks Guys for the feedback,I'm still in Dakar(Senegal),will be in South Africa at the end of september,daarom kan ek nie fotos opsit.
Greetings.
Roger
martyn
Full Name: Charles Fry
Nickname: Charlie
Home Town: Robertson
Current 4x4: Patrol 4.5
Has thanked: 83 times
Been thanked: 41 times
Post by martyn »
Hi. if its the short concertina pipe that has 2 smaller pipes joining it as per part 3 on the 3rd photo, it cost R2700.00 from Nissan. You can get a silicon concertina hose and a steel tube with 2 smaller tubes welded on and make one up for about R300+- Its the one after the airflow meter so if split causes problems when you accelerate or need power.
Diem Dulcem Habes
Have a good day
