URGENT HELP NEED TO BORROW WHEEL BEARING PRELOAD TOOL
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Has thanked: 51 times
Been thanked: 10 times
Post by NMAD »
Hi all
I have just put in new bearings and races on the front axle and I need to borrow someones wheel bearing nut torque tool urgently please.
I stay in Table view Cape Town and would like to drive out to whomever may have one in the area and then torque them at your place.
They are currently only set finger tight so need to pre load them. I have a torque wrench which I will bring with.
Please help.
Noel
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Re: URGENT HELP NEED TO BORROW WHEEL BEARING PRELOAD TOOL
Post by David »
Hi - if you are willing to drive all the way to Stellenbosch you can use mine
0 eight two eight eight three one eight five two
Peter Connan made that tool as well. :thumbup:
jonathan
Full Name: Jonathan Venter
Nickname: jonathan
Home Town: Jacobsbaai
Current 4x4: 2005 4.8 GRX
Has thanked: 9 times
Been thanked: 43 times
Post by jonathan »
Noel you are welcome to use mine as well, I'm in Jacobsbaai, close to Saldanha, but it might be a bit too far! I could always send it to you as well.
SCUBA Patrol
Full Name: Phillip Jacobs
Nickname: Phillip
Has thanked: 31 times
Been thanked: 32 times
Post by SCUBA Patrol »
Dawid goed om te weet jy het een en dit amper op my voorstoep! :biggrin:
Phillip
2006 3l with MADMAN
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Post by NMAD »
David wrote:Hi - if you are willing to drive all the way to Stellenbosch you can use mine
Thanks David! I will call you later today :thumbup:
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Post by NMAD »
jonathan wrote:Noel you are welcome to use mine as well, I'm in Jacobsbaai, close to Saldanha, but it might be a bit too far! I could always send it to you as well.
Hi Jonathan
Thanks for the offer, such a good spirited bunch on this forum :thumbup:
Will prob go to Stellenbosch as its closer but thanks anyhow for the offer :salute:
David
Nickname: David
Post by David »
Noel, How is the auto hub? Could you fix it?
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Post by NMAD »
David wrote:Noel, How is the auto hub? Could you fix it?
Hi David
Yes thanks I got it sorted, it just needed to be greased and now its working 100%.
Thanks for helping with my wheel bearings :thumbup:
Peter, when are you making more of those wheel bearing tools? I want one please....
