Strange noise from front wheels
jonathan
Full Name: Jonathan Venter
Nickname: jonathan
Home Town: Jacobsbaai
Current 4x4: 2005 4.8 GRX
Has thanked: 9 times
Been thanked: 43 times
Post by jonathan »
Hi guys
Every Friday I drive about a 8km section of gravel road. I use the opportunity to engage 4H to give everything that needs it a workout. Last week after doing this and being back in 2H, I heard a sound very much like the sound of having a playing card stuck to your bicycle's wheel coming from the driver side front wheel. It disappeared after a few hundred meters. After stopping and checking for obvious problems and driving again, there was a horrible scraping noise coming from the passenger side. Almost as if a small rock got stuck between the brake disk and baffle plate. I slowed down and just before coming to a complete stop, there was a clack, and the noise stopped.
Unfortunately it came back and again just before coming to a complete stop there was the clack again but this time I realised that it was definitely some engaging or disengaging. I could not only hear the clack, but feel it as well. Same thing happened this morning, but luckily after the first clack it was fine, drove it 4H again, no problem. I have a suspicion that this afternoon it will do the same thing!
Any thoughts? I am thinking either the hubs or transfer box for some reason is not disengaging properly?
Any thought are welcome!
Re: Strange noise from front wheels
Maybe next time you do it again just manualy lock the front wheels and hear if the same sound is there - if it is not there then maybe the auto lock take some time to lock the wheel.
jonathan
Nickname: jonathan
Post by jonathan »
Herrie wrote:Maybe next time you do it again just manualy lock the front wheels and hear if the same sound is there - if it is not there then maybe the auto lock take some time to lock the wheel.
Dankie Kobus. Ek het ook daaraan gedink, maar die geluid is net wanneer ek terug is in 2H. In 4H is daar geen geluid of probleme nie.
Been thanked: 473 times
Could it be that the grease inside the hub has gone a bit thick and restricting the movement, so its trying to auto engage but just not quite getting there. Maybe take the auto hub off and give it a good clean and regrease.
bogeyman
Full Name: Christo Boegman
Nickname: Chris
Been thanked: 102 times
Post by bogeyman »
That noise is definitely the free wheel hubs that are tying to engage at speed.
Usually this happens when winter approaches and the grease becomes thicker when cold.
There are a few threads about this on the forum.
As Cedrick said , remove , clean and re-grease. Detail instructions are on the mentioned threads.
PathMaker
Full Name: G
Nickname: PathMaker
Home Town: Centurion/Pretoria
Has thanked: 13 times
Been thanked: 46 times
Post by PathMaker »
Hi Guys.
You are all close to the right answer.
My recommendation is to change the transfer case oil by adding some ATF oil to make it a final of 20% ATF and 80% 75W80 oil. Reason is to thin out the oil and thereby stopping the propshaft from turning when in 2H, whichever is causing the auto lockers wanting to engage. This is common in winter.
Try it and give me feedback.
Graham
jonathan
Nickname: jonathan
Post by jonathan »
Thanks guys, appreciate it!
Graham I already have 100% ATF in the transfer case. I did a oil change when I got the troll three years ago. Only done about 20 000km since then. Although, I had the clutch done last year June, could they have drained the oil perhaps and replaced with something else?
Been thanked: 430 times
Jonathan, ek kan jou amper wet dis een van jou voor hubs wat begin droog raak of moeilikheid gee.
Ek het die naweek n 4x4 event gedoen en een van my hubs het my op baie obsticles in die steek gelaat. Ek het ok n lelike geluid gehoor as ek met die hubs op "lock" gery het met die kar in 2H...... was baie onaangenaam.
Ek het toe gister aand die hubs heeltemal gestrip en behoorlik skoon gemaak, ge olie en weer aanmekaar gesit.
Jy sal nie glo hoe hulle nou werk nie.....
My linker hub was nie geseel met bietjie silicone waar hy vas maak nie en het duidelik bietjie water in gekry.... hy het omtrent heeltemal vas gesit en kon nie meer werk nie.
Ek sal more aand my replacement hub wat ek gekoop het sttip, skoonmaak en stap vir stap fotos neem en n thread maak vir dit. Dis nie so moeilik nie en gaan julle baie geld spaar
jonathan
Nickname: jonathan
Post by jonathan »
Dis reg so dankie Michael. Ek dink ek gaan die hubs strip sodra ek kans kry, hopelik Vrydag. Net om seker te maak gaan ek die olie in die transfer case ook check. Miskien dit maar drein weer volmaak met nuwe ATF.
jonathan
Nickname: jonathan
Post by jonathan »
Het uiteindelik by die hubs uitgekom en ongelukkig is die oorsaak toe die regter kantse hub. 'n Paar los stukkies yster binne in gekry wat duidelik afgebreek het en die oorsaak was dat hy permanant gelock is :doh:
Soos dit my lyk is dit nie eintlik moontlik om die hubs te herstel nie so ek vermoed daar is 'n nuwe een in my nabye toekoms!
Ek sien die onderwerp van automaties vs handmodel is al n paar keer bespreek so ek gaan nie weer dit opbring nie, maar as enigiemand 'n voorstel het waar om hulle in die hande te kry (behalwe Nissan), sal dit baie waardeer word!
