Nissan Neo ZD 30
Dave Faddel
Junior Member
Junior Member
Full Name: Dave Faddel
Nickname: Dave
Home Town: George
Current 4x4: Pagero 3,5 Gen 2, looking at buying a Patrol GQ
Nissan Neo ZD 30
Post by Dave Faddel »
Hi all, long time since I have visited or contributed to the site. Well here goes, asking for some help for my grenaded ZD30. I blew the motor a while ago and have simply parked the Patrol in my garage. The time has arrived to make a decision. I have found a very good ZD 30 motor from a Nissan Neo.This was very obviously not available in South Africa so have very little to go on. I have got an itch to buy the motor (a BIG itch) but am worried. All info I can get seems the Neo was front wheel drive it seems (don't actually know) It's slightly down on power and quite a whack on torque (about 40nM if I recall)
Has anybody any idea of the motor, will it fit onto my auto box. I recon it's from about a 2006/7 Neo and my Patrol is 2001 ... :think: Any help would be highly appreciated.
Re: Nissan Neo ZD 30
A F I K the ZD 30 came in different vehicles -- even th e2003 Terrano II came with it [also the down rated one to th ePatrol's engine.
Deon, aka: THABIES [also on this site] had his grenade replaced with a ZD 30 from the Hard Body .. and he has not stopped smiling since.
I dont think anyone on this end woul know about the NEO .. BUT I THINK the front wheel drive models het a weaker crank & bearing requirement .. but that's guesswork.. Mr Connan ?? how you think?
I dont know the ins and outs of the z30 but what i do know is that a 4.2 bolts in there perfectly. ...look a biggles car frans has converted a couple of 30l to 4.2 turbo diesels
Looking at much less hassles . They are avalible and it seems the better way to go were in the world are you?
Has thanked: 61 times
Been thanked: 257 times
I do not know about the Neo, but I do know that these engines are not all the same, and hence may not be as simple a transplant.
See this post:
http://www.patrol4x4.co.za/viewtopic.ph ... 2&start=10
In 2011, Andre Odendaal bought an import ZD30 for R20000 to replace his grenade. He specifically asked for a Patrol engine. On closer investigation they found that it is a Terrano engine and that the two engine management systems are not compatible, which would have meant additional costs. The importers of the engine argued that it is suitable for the Patrol when it was not the case.
The Neo may be compatible. But make very sure of this from a trusted and knowledgeable source.
Tinus lotz wrote:I dont know the ins and outs of the z30 but what i do know is that a 4.2 bolts in there perfectly. ...look a biggles car frans has converted a couple of 30l to 4.2 turbo diesels
Dave, I think you are based in George?
If Frans is prepared to do it for you, he is your best bet.
If you can lay your hands on the Terrano ZD 30 engine .. GRAB it [and the ICU with it ... ]
Get the info from Reenen Kritzinger and warm up that engine .. :oldtimer: :oldtimer: :oldtimer:
DEVOLSCHENK
Full Name: DAVID VOLSCHENK
Nickname: VOLLA
Home Town: WARMBATHS (BELA BELA)
Current 4x4: 3.0DTi GRX met td42ti
4.2D GQ SUV (DIE LIMMO)
4.2d GQ BAKKIE
1100 GS
Been thanked: 7 times
Post by DEVOLSCHENK »
Dave, my brother Jeanne replaced a grenade motor with a TD 42 Turbo. He is sover happy with the car that he is now converting his one 4.5 into a Diesel aswell.
I would suggest you good for a 4.2 TDI if you can
We have found a motor going to start building a td42t soon are you interested?
NamibiaPatrol
Junior Member
Junior Member
Full Name: W
Nickname: D
Home Town: Windhoek
Current 4x4: Nissan GQ Patrol
Post by NamibiaPatrol »
Tinus,
Het julle n factory td42t of gaan julle n TD42 convert turbo toe?
What will the price be?
Tinus lotz wrote:We have found a motor going to start building a td42t soon are you interested?
Hi micheal is going to build the engine iam going to be spanner boy ..lol have a look under my 4.2 turbo diesel ...we are gonna strip the motor and build a turbo 4.2 with correct pistons ect . Pm me your no and we can tallk ....dont know what needs to be done to it but it will know shortly. :salute:
