Chuck's standard bumper (for a '98 Y61 Patrol) is just gathering dust. It consists of the aluminium center bumper with recovery point, both the rear light pods (excludes the bulb fittings inside the light pods), the mudflaps and the accompanying tow bar with tow ball.
Collecting it will be payment enough, but if you insist you may always to ease the withdrawal symptoms...
Christo (the snake man)
If you are not going to use the corners, I will take those. Mine has had some better days. Bought the Patrol with drooping corners and quite damaged. Or if yours is still in good nick?
Hi Marino. I have attached pics of my bumper and what caused the damage, trying to extricate myself from deep mud. The dented aluminium was when I forgot about a tree stump and reversed into it upon leaving a campsite early one morning. The right hand side looks ok. If I am able to get the bumper, you can have anything that I dont use.
You guys are both so fa-a-a-a-a-ar away! Won't postage/shipping/courier costs be more than simply getting the missing bumper bits at a scrapyard? The bumper is in pieces, so it'd be relatively easy to send you guys just the bits you want if cost is not prohibitive...
Barry, my bumper's aluminium strip has a very slight indentation (visible on the photo, just to the tight of the recovery loop), but nothing as bad as yours! If I send it without the recovery hook it will be even lighter still.
Marinus, the corners are light plastic so I presume they'd be cheap to send. Do you need the lights & mud flaps too?
I am here in Johannesburg until Monday so within easy reach of Pretoria where I believe you are. If you pm me your phone number I will get the details from you.
The courier cost will probably be R100 - R200. I still have some stuff from David Volschenk at Graham that I need to collect. You can drop it there if it is in your way. But Gupster got firs pick. If he does not use the corners I will take them.
