Viscous fan for 4.2Diesel wanted
- Full Name: philip bekker
- Nickname: philip
- Home Town: lonehill
- Current 4x4: 1995 nissan patrol 4.2 D SGL, 1999 Patrol 4.2 D p/u, 2004 Patrol 4.8 GRX.
- Home Language: afrikaans
- Been thanked: 2 times
Does anyone know where i can get a viscous coupling for a 4.2D.The fan in the Patrol i bought has been fixed to turn permant with the waterpump. Nissan qoute me R3207 excl. vat.
Thanx
Thanx
- tour de frans
- Been thanked: 22 times
Re: Viscous fan for 4.2Diesel wanted
Pieter,help hier asb. Het jy nie die part nr van jou 3.0l se fan nie,want dit sal op die 4.2 ook pas.Dit lyk my die handelaar rook hulle kouse voor hulle die pryse maak.
Raka,Pieter en ek het altwee onder R200 vir ons fanblades betaal(sonder die viscous)en die goed is presies dieselfde.Ek het my part nr versit,hoopelik kan Pieter help.
Ek dink ons moet vir Pieter nominate as die "organiser"op die forum in die Kaap sooswat ons moderators het of so?
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
- Pieter du Toit
- Nickname: PJ of ook Whitey
- Home Town: Welgemoed
- Been thanked: 6 times
Raka,
I replaced mine less than a month ago - bought it from a spares shop in CT - 150 BUCKS
EXACT same thing as the Nissan Fan!!! Nissan here quoted me R1550-00 for the fan
(without the viscus of course) - I still have my old fan at home and will check for you tonight.
You can also try places like Midas, Auto Zone, and basically any place selling car parts - but if you don't come right let me know I can buy it here in CT and courier it to you - will still be cheaper!!!
One question - from the price you said they quoted you - is that for the fan with the viscus included??
Pieter du Toit
MUFASA
Cell no: 072 606 7007
Fax no: 086 500 9333
MUFASA
- Pieter du Toit
Frans kom hier dalk $$$ saam met die "pos"??tour de frans wrote:Ek dink ons moet vir Pieter nominate as die "organiser"op die forum in die Kaap sooswat ons moderators het of so?
Pieter du Toit
MUFASA
MUFASA
- Johan B
- Full Name: Johan Buys
- Nickname: Johan
- Current 4x4: Nissan Patrol 4.2D GL '99
Nissan het gesukkel om die regte fan te kry vir my 99 4.2d.
2106006j10 was verkeerd maar
2106005d01 pas. R1840 en 1 week later.
- Pieter du Toit
Raka,
Here's a photo of my fan that came off my Patrol (3.0d 2002 Model) - it is the same as the one that is on Frans' s 99 4.2 D.
There is a couple of number imprints on the fan and I dont know which one is the actual part number - but none of the numbers is anything close to what Johan B posted above. Johan may be you could comment here on whether it is also the same as yours - then at least we have narrowed down the part number issue. Anycase the numbers imprinted on the plastic of my fan is:
450-13-6
SAE [PP]
>PP-GF3< OR >PP-6F3<
2W201
I got the exact same size fan from a spares shop in CT - same number and shape of the blades - like I said 150 bucks later!!!
Hope this helps - but my offer (check my first post) stands if you don't come right.
450-13-6
SAE [PP]
>PP-GF3< OR >PP-6F3<
2W201
Pieter du Toit
MUFASA
MUFASA
- Gerrit Loubser
- Full Name: Gerrit Loubser
- Nickname: Gerrit Loubser
- Home Town: Richards Bay
- Current 4x4: None
- Been thanked: 11 times
None of those look like a Nissan part number. Could it be that your car already had a pirate fan?Pieter du Toit wrote:450-13-6
SAE [PP]
>PP-GF3< OR >PP-6F3<
2W201
By the way, the >PP-GF3< is recycling information indicating that the fan is made out of polypropylene that is glass-filled for strength.
- Johan B
- Nickname: Johan
The first fan Nissan supplied looked identical to the old one but the holes were slightly smaller and did not 100% align with the holes on the coupling. The second one fits perfectly.
It is similar to the one on the picture above but I am not able to tell whether the holes is the right size.
- Pieter du Toit
Johan
Thanks - the holes fitted perfectly on my 3.0l D and on Frans's 4.2 D - we have exaclty the same fan - so it must be the right one!!
Raka what happened to you - you have not made any comments yet
- did you come right??
Pieter du Toit
MUFASA
MUFASA
- Gerrit Loubser
- Current 4x4: None
I am not sure what the differences are, but the fans for different engines all seem to have different Nissan part numbers.
From this thread:
From this thread:
Gerrit Loubser wrote:Note that the Nissan part numbers for the fans of the TB45E, TB48DE, TD42 and ZD30 engined Patrols are all different. It might still be possible to fit a fan designed for a different motor, but I think it is likely that the blade pitch might vary between different fans, because they will be designed with a particular engine's heat load and operating speed range in mind.
By the way, the part numbers for the fans are:
TB45E: 21060-WJ100
TB48DE: 21060-VC200
TD42: 21060-06J01 or 21060-05D01
ZD30: 21060-2W201
