GQ headlights
- offroadbiker
- Full Name: Dirk de Clerk
- Nickname: ORB
- Home Town: Krugersdorp
- Been thanked: 275 times
GQ headlights
I need a new set of GQ headlights for the Troll.
Think someone said that the Defender's lights would fit?
Any other options out there?
Tx
Tx
Re: GQ headlights
Don't the golf I (one) headlights work too?
Re: GQ headlights
Yippp - off to MIDAS -- and buy the lights over the Countre -- The Golf lights do fit BUT you must MAKE it fit .. the lugs and clamps dont fit straight up
Just buy the housing [glass] unit and replace .. and use a decent globe [H4] set :-)
- David M
- Full Name: David Marais
- Nickname: David Marais
- Home Town: Midrand
- Has thanked: 20 times
- Been thanked: 97 times
Re: GQ headlights
Graham did an HID conversion for me on my GU...... probably the most worthwhile thing I have done to the vehicle..........
- bogeyman
- Full Name: Christo Boegman
- Nickname: Chris
- Current 4x4: 2005 4.8 GRX
- Been thanked: 102 times
Re: GQ headlights
Dirk,
There are many options.
If you want serious light , go for a very expensive HID kitt.
I have found that the Hella kitt you can buy over the counter at any Midas works the best. It fits and Hella is good quality. Avoid the cheap Chinese options.
Groetnis
Chris.
Groetnis
Chris.
- offroadbiker
- Nickname: ORB
Re: GQ headlights
Need to replace the entire light as they are no longer "usable" after filling them up with water and mud
Re: GQ headlights
Dis presies wat ons jou probeer vertel =--Kry die HELLA h4 eenheid by MIDAS -- dit is die hele lig, sonder globe ..
OF as jy wil preuts wees, kry die "sealed unit" soos wat hulle op die HUMMER sit ... dan het jy kerslampies om n sexy atmosfeer te skep :-)
Nehou die fitting - kry die nuwe glas en reflector -- dit "twist & turn" met sulke hakies .. eezy peezy,, tot hirri outppi knol kan dit doenb :-)
[Het vir THOR nuwes ingesit, dit was R480 stel gewees [MAAR dis MY prys, sal jou meer kos]
- Has thanked: 1131 times
- Been thanked: 1044 times
Re: GQ headlights
Dirk, nie dat ek se jy moet hulle nie vervang nie (aangesien die hoofligte een van die swakste punte van die GQ is), maar ek haal myne gereeld uit om die modder en water uit te was?
