Rear Recovery Hook
- G-MAN
- Full Name: A.G.HOLMES
- Nickname: G-MAN
- Home Language: Engels
- Has thanked: 3 times
- Been thanked: 9 times
- G-MAN
- Nickname: G-MAN
- G-MAN
- Nickname: G-MAN
- G-MAN
- Nickname: G-MAN
- G-MAN
- Nickname: G-MAN
- Saltman
- Full Name: Herbie Hellstrom
- Nickname: Saltman
Re: Rear Recovery Hook
Looks Great Gerhard
The backplate welding - did you cut a hole in the mounting plate and therefore shaped the hook portion to fit through the mounting plate and then welded it to both the front and rear of the mounting plate?
If so, do you sell them?
As die prys nie te dronk is nie, soek ek ene asb!
Saltman:
- Ross
- Full Name: Ross Holland
- Nickname: Ross
- Home Town: Cape Town
- Has thanked: 7 times
- Been thanked: 14 times
Looks good Gerhard!
Is the bolt pattern the same as for the earlier series GU? If it fits I want one....with Saltmans pre-condition of course
Quote Saltman: "As die prys nie te dronk is nie, soek ek ene asb!"
Ross
aka "The Polar Bear"
- G-MAN
- Nickname: G-MAN
Morning guys. The center is strait through the middle, then grinded to 45 degree angle, welded both sides and ready to pull out any .......!
The bolt pattern is the same, straight swop and the bolts is long enough.
Will work out the price today guys.
Sucks Gas and Hauls Ass!
- Tjaart
- Nickname: TJ
- Been thanked: 2 times
Gerhard
Dit lyk Wonderlik!! Baie slim idee en baie mooi uitgevoer!!!
THE BRAVE
says
Aut PATROL aut nihil
Aut vincere aut mori
says
