Looking at buying 2006 4.8 auto
- Full Name: Paulo
- Nickname: da Silva
- Home Town: Kempton Park , Gauteng.
- Current 4x4: Nissan Patrol 4.8grx
Suzuki Sidekick 1.6 - Home Language: English
- Been thanked: 4 times
Im looking at buying a 4.8 auto with 100 000km. What should I look out for and how reliable is the autobox on these Patrols.
I will also be servicing the Patrol. Besides oil and filter what else should I check or replace.
- Full Name: Jacques Strauss
- Nickname: NISMOnator
- Current 4x4: 2007 Nissan Patrol 4.8 GRX
- Has thanked: 19 times
- Been thanked: 3 times
Re: Looking at buying 2006 4.8 auto
Hi pdasilva,
Ive had my Patrol for almost a year now. Please see this link for Q&A before I bought my Patrol. http://www.patrol4x4.co.za/viewtopic.php?f=42&t=2641
Fuel consumption is 3.5 - 5 km/l depending on what you are using your Patrol for and fuel you use? Other than that it puts a big smile on your face when you floor it. When doing the last mentioned do not look at the fuel gauge as it goes like a speedometer in negative direction as your rev and actual speedometer climbs to positive, this might make you depressed.
So just concentrate on the acceleration?
Hope you find a good one, at Centurion Suzuki there is a 2007 4.8 GRX for about 250 000. I haven't had a look at it so I wouldn't know in what shape it is?
- David
- Full Name: David Prinsloo
- Nickname: David
- Home Town: Stellenbosch
- Been thanked: 49 times
Good choice
I also service mine myself and I would do the following to any second hand one:
Get it - you will not be sorry
- Change oil
Change fuel filter
Change spark plugs
Change air filter
Change belts
Check front wheel bearings for play & adjust
Check all suspension bushes for play & wear
Flush radiator and replace antifreeze mixture
Replace brake flued
Fill fuel tank
- Full Name: nico pienaar
- Nickname: beast
- Home Town: Ruimsig Roodepoort
- Current 4x4: Patrol 4.8
Navara 4l
Safari 2.8 - Home Language: afr
Good choice. Make sure it has not been abused.
I have had my Patrol for almost 6 years now. I have never been sorry I bought a 4.8 Patrol. I average a fuel consumption of 18.3 l/100km's.
Hopy you have lots of fun with it.
- Chris Skinner
- Full Name: Chris Skinner
- Nickname: Chris
- Has thanked: 10 times
- Been thanked: 53 times
I have owned both 4.5 and 4.8.
The difference in fuel consumption is negligible, but the difference in power is obvious.
The tiptronic box is amazing!
Only problem I ever had was with the 4.5 when the 5th gear stripped - too much towing in 5th.
When towing with the tiptronic just park it in 4th manually and leave it there.
Never a hiccup on the 4.8.
You will not be sorry!
- Has thanked: 62 times
- Been thanked: 257 times
In addition to David's list I would add the following:David wrote: Change oil
Change fuel filter
Change spark plugs
Change air filter
Change belts
Replace brake flued
Fill fuel tank[/list]
That's it - the gearbox is tuff and excellent with the tiptronic function but you should replace the oil around 120k km.
Change the diff oils and gearbox oils every 30,000 - IF you are the kind of guy that makes the machine work very hard on tracks. Otherwise follow the service manual intervals, which are far less frequent. On the gear and diff oils, if you are doing it yourself, please do not overfill it. EWven Nissan tends to overfill it. If at any time, you open the top plug and oil runs out, it is too full, putting the gear housing under pressure and heat up.
I bought my Troll second hand and I do not no how it was driven previously, but I had to replace my knuckle bearings at one point too.
Bearings eventually go on all machines, even on Trolls, and should be checked.
- Full Name: Paulo
Thanks for all the advice guys. I currently own a 2005 3.0 DI manual with EGT gauge,catch can and intercooler fan.
Thus far the car has been awesome but would like to upgrade now to the 4.8 for the extra power and the extra fuel bill.
I was just not sure how the auto compared to the manual but it seems that they just as reliable.
If you do 4x4, then the auto is cheating
I prefer manual because it is more fun, but require more driving rather than being driven.
Auto is more forgiving on a steep uphil.
The manual Patrols have bigger rear diffs than the autos (260 vs 233). I would like to think that this makes them even tougher.
You will miss the economy of the 3di
I know I do. And that is with the Lexus Petrol, which is supposed to be a little lighter on fuel than the 4.8
- Full Name: Paulo
OK , I have had a looked at a Patrol for a very good price and under 90 000km on the clock with Nissan service history up to 45000.Problems that I picked up below that i need to fit the bill for.
The dash will need to be recovered.
Right mirror needs to be replaced as the housing is damaged.
Rear aircon knob is missing.
Anybody have these parts lying around and a decent place to have the dash recovered?
Thanks.
Thanks.
