An almost handgranaded ZD30
Jefe
Junior Member
Junior Member
Full Name: Johannes Henckel
Nickname: Jefe
Current 4x4: Nissan Patrol 3.0 Diesel
Post by Jefe »
Two years I bought a 2004 3.0 D with 125' ks on the clock. The car was apparently well looked after and my first trip took me to the Zambezi valley. No problems other than a slight loss in cooling liquid. I had the vehicle checked for a leak in the cooling system but everything seemed to be ok. 2 years and 15' ks later the water loss got serious, starting problems and about 2 liters per 1000km. I had the head removed to check for cracks, Bingo a hairline crack in the head. I took the vehicle to SAC in Centurion and further cracks were identified in the pistons. I decided to go for a total overhaul (did not have much of a choice). When the engine was removed I got the bad news that the flywheel was totally worn. That set me back another R 25' (flywheel only), a real bargain I must say. Anyway, SAC did a great job and also installed an EGT gauge. The engine runs like a dream but there was an annoying drone, engine vibrations were transmitted to the chassis. After installing new engine mounts the drone was diminished but it is still there. Has anybody come across the same problem? Any advice would be welcome.
What did I learn: never buy a used 3.0D Patrol with a tow hitch, especially if you do not know who the previous owner was and how he treated his vehicle. If I would have joined the forum before I made the purchase I could have saved an awful lot of money
Re: An almost handgranaded ZD30
Well now that you have a "new" motor in there.... and an EGT monitor.... 500 000km here you go..... many trips to Zims on that!!!!
After all is said and one about the ZD 30 enin. If I can exchange the Prado today for a post 2005 Patrol ZD30, I would do so - even though the Prado has only 10,000km on ..
BUT I now know how to protect that ZD30 enjin -- ask BOEZMAN the H/B abkkie standing outside, all smiles, with 226 000 km on the clock - and still going places where others fear to follow.
Jefe - pleased to make your aquintence - and all the best with your Trol
pdasilva
Full Name: Paulo
Nickname: da Silva
Home Town: Kempton Park , Gauteng.
Current 4x4: Nissan Patrol 4.8grx
Suzuki Sidekick 1.6
Been thanked: 4 times
Post by pdasilva »
Hi do you mean R25 000 for the fly wheel only , if so you got wripped off badly. I just replaced my dual mass fly wheel with a Solid fly wheel which cost me around 10k including new clutch kit and labour. A new DMF will cost 16K at Nissan. With the solid mass flywheel you do have more vibration but only at very low revs.Maybe confirm whith SAC if they replaced with a DMF.
Traveler
Full Name: Heinrich Stoltz
Nickname: Traveler
Home Town: Springs
Current 4x4: Patrol 3.0 GL,
Post by Traveler »
Welcome Jefe.
Did they do any compression and carbon tests before the head was removed and the cracks were discovered?
martyn
Full Name: Charles Fry
Nickname: Charlie
Home Town: Robertson
Current 4x4: Patrol 4.5
Has thanked: 83 times
Been thanked: 41 times
Post by martyn »
Hi, does anyone have a damaged d/m flywheel or solid flywheel? Id like to take a few mesurments off of one.
Diem Dulcem Habes
Have a good day
Jefe
Junior Member
Junior Member
Nickname: Jefe
Post by Jefe »
Yes a carbon test was done. The flywheel is a DMF (I was charged R 22000 ex Vat by SAC). I considered getting a solid flywheel but the reported vibration put me off.
Izak
Full Name: Izak
Nickname: Sakkie
Post by Izak »
I think oom Mac should be delegated to have a chat with SAC Pretoria. If they charged R6000 profit just to supply a Flywheel I will seriously reconsider before I ever take my Patrol to them again.
All stories have two sides so before they are labeled lets have their side of the story.
:mytwocents:
Traveler
Nickname: Traveler
Home Town: Springs
Post by Traveler »
Jefe wrote:Yes a carbon test was done.
Was the result negative or positive for carbon?
pdasilva
Full Name: Paulo
Nickname: da Silva
Suzuki Sidekick 1.6
Post by pdasilva »
martyn wrote:Hi, does anyone have a damaged d/m flywheel or solid flywheel? Id like to take a few mesurments off of one.
I have a DMF that you can sample , contact me on 082 448 1075 im in kempton park.
