Remote control programming
- Full Name: Paulo
- Nickname: da Silva
- Home Town: Kempton Park , Gauteng.
- Current 4x4: Nissan Patrol 4.8grx
Suzuki Sidekick 1.6 - Home Language: English
- Been thanked: 4 times
I purchased a new remote for my 2005 Patrol. Does anybody have instructions oh how to programme the remote.
Thanks.
Thanks.
- Newbie
- Full Name: Derald Diedericks
- Nickname: Didi
- Home Town: Kriel
- Been thanked: 2 times
Re: Remote control programming
Nissan Patrol Reference Document
Page 49 of 138
KEYLESS REMOTE - REPROGRAMMING
Heres how it’s done:
1. Get in your vehicle and close all the doors.
2. Using your drivers lock button, lock all doors.
3. After doors are locked take your ignition key and insert it and remove it from ignition
switch approximately 6 times within a 10 second period a reasonably quick way. Make
sure the key is all the way out before inserting again.
4. The hazard lights should flash and the doors will unlock.
5. Re-lock the doors using the drivers lock button.
6. Put the key in ignition switch and turn to the on position. Do not start the engine or
you will have to start again.
7. When in the on position hit the lock button on the remote, one time, the hazard
lights should flash.
8. Turn the ignition off and remove the key, open the drivers door and close, then test
the key.
Note: You will have to reprogram all your remotes at once, if you do not your old remotes
will not work. If you have other remotes press their buttons within 7 seconds of the
first one.
Hope this help.
Page 49 of 138
the key.
first one.
Hope this help.
- Jorrie
- Full Name: Jacobus Jordaan
- Nickname: Jorrie
- Has thanked: 184 times
- Been thanked: 165 times
Whilst talking about remotes, where can I buy a spare remote for my 1998 Y61?
- Full Name: Paulo
Hi there.Didi wrote:Nissan Patrol Reference Document
Page 49 of 138
the key.
first one.
Hope this help.
I have tried this but with no success.I dont get past point 3 my hazards never get to flash.
- Full Name: Paulo
The friendly guys at Mark white Nissan assisted me.
You need to turn the ignition switch ON and OFF six times before then hazards kick in. Then you can follow the procedure above.Also the door does not need to be closed when doing this.
- Tony
- Full Name: Antonio Barone
- Nickname: Tony
- Home Town: Greyton - W/Cape
- Been thanked: 40 times
I had both my wife's Xtrail remotes replaced and reprogrammed as well as one of mine from Craighall Locksmiths - cost a lot less than Nissan - I just cannot remember the guy's name - Tel No. is 011 787-2199 or 083 602-6026.
- Jorrie
- Nickname: Jorrie
Thank you very much Tony. I will certainly follow it up.Tony wrote:I had both my wife's Xtrail remotes replaced and reprogrammed as well as one of mine from Craighall Locksmiths - cost a lot less than Nissan - I just cannot remember the guy's name - Tel No. is 011 787-2199 or 083 602-6026.
- SJBS
- Full Name: Steve Barnard
- Nickname: Steve
- Home Town: Ellisras
- Current 4x4: 99 Trol 4500 GRX
Range Rover
Terrano - Home Language: Afrikaans
- Has thanked: 5 times
Jorrie wrote:Thank you very much Tony. I will certainly follow it up.Tony wrote:I had both my wife's Xtrail remotes replaced and reprogrammed as well as one of mine from Craighall Locksmiths - cost a lot less than Nissan - I just cannot remember the guy's name - Tel No. is 011 787-2199 or 083 602-6026.
Jorrie,
Let us know how it panned out - I also have a '98 GRX with the buttons pushed through... Thus will have to invest in some new remotes soon.
