Ls1 convertion
tour de frans
Been thanked: 22 times
Ls1 convertion
Post by tour de frans »
Goeie Dag Almal.
Ek weet Oom Mac gaan vir kiekies vra. Ek sal dit later opsit. :thumbup:
Wil net noem My Patrol loop nou met n LS1. Die Convertion het my 4 weke geneem om te doen.
Kar loop baie lekker en petrol lyk sover mooi ook.
Frans
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
Re: Ls1 convertion
Vertel ons meer !!!!!!!!en plak prentjies :thumbup:
Re: Ls1 convertion
Ek wag ook daarvoor!!
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Re: Ls1 convertion
Post by Chris Skinner »
Please tell us more - is it a gen III LS1?
Power and torque?
Where was the mod done, costs, etc.... :layrubber: :layrubber: :layrubber:
Re: Ls1 convertion
Is daar plek vir n viscus gewees of gebruik jy n hidrolc fan???? En gebuik jy die poatrol ratkas?????? :salute:
tour de frans
Re: Ls1 convertion
Hallo
Ek gaan engels try. Its a gen 3. Drive by cable not wire. I like the drive by cable. less electrics and cheaper licence to access the ecu. I wired the GM wireing to the patrol. Very easy. only 5 wires. exept for the rev conter and oil light etc. I used the Patrol gearbox with a the 6l Lumina clutch. There were some other mods I had to do ie: the fuel pressure regulator are intank with the Lumina. I had to fit a external regulator. No manifold do fit. Not the 5.3, 5.7, 6.0 or even the ls2. Some say that a corvette might work. I made branches out of mandrill pipes. Running a dual 63mm exhaust from the front to the back. A nice x-pipe in the front to mix the super v8 sound. I used the hydraulic fan. driving it with the chevy powersteer pump. Had to add a solinoid to turn fan on and off. The ls1 has a v-belt tentioner that I removed and fitted the nissan powersteering pump. So that stayed std.
I had to swop the sump out with a rear boal sump to clear the front axle.
The Patrol pull like a train, start and Idle perfect with the GM ecu. Idle control works perfect to. It is a realy nice convertion.
Ek sal later prentjies opsit. Ek ry nou eers lekker rond
Frans
tour de frans
Re: Ls1 convertion
Al wat ek nie gelaaik het van die convertion nie, Ek moes my kar laat datadot voor ek die engine clearance kon doen. Maar dis ook klaar, te danke aan my vrou wat al die rond ry werk gedoen het. Datadot, hulle spray n kode 88 keer in n mens se kar.
tour de frans
Re: Ls1 convertion
Meer oor die radiator fan. Tinus daar is nie plek vir n vicous nie. Daar is baie plek tussen die engine en die radiator ja. maar die waterpomp pully sit te na aan die intake manifold. So n waaier sal nie kan draai nie. n Mens kan ook nie die waaier verleng nie want die engine se inlaat pyp gaan dit nie toelaat nie.
Daar is n manier om n viscous te gebruik. Ek sou eerder die hidroliese roete gaan. Beter as n viscous in my oe.
As jy die 'truck style' intake gebruik kan jy n viscous hardloop. Die intake se runners draai lekker hoog. Dit skuif dan die intake pyp ook op. In n Patrol sal dit ook werk en die bonnet sal reg toemaak. Die engine sit laag. Hoog genoeg om die diff te clear met n rear hump sump natuurlik.
Didi
Full Name: Derald Diedericks
Nickname: Didi
Home Town: Kriel
Current 4x4: Nissan Patrol
Re: Ls1 convertion
Post by Didi »
Dagse,
Ek wil een van daai menere in my Hardbody sit, maar waar het jy 'n adaptor of bellhousing en flywheel gekry.Dis al wat ek kort om te begin.
tour de frans
Re: Ls1 convertion
Hallo
Bellhousing by Gilo engineering. Flywheel hou ek by chev.
