Air Suspension - "bladder"
- offroadbiker
- Full Name: Dirk de Clerk
- Nickname: ORB
- Home Town: Krugersdorp
- Has thanked: 189 times
- Been thanked: 270 times
I've noticed (heard) that the left hand bladder of my air suspension seems to have a puncture, can this be fixed/patched or does one need to replace the blader or maybe both?
Re: Air Suspension - "bladder"
I'm not going to ask how you got a puncture
in your blow up........ bladder.....
- offroadbiker
- Nickname: ORB
offroadbiker wrote:I've noticed (heard) that the left hand bladder of my TROL'sair suspension seems to have a puncture, can this be fixed/patched or does one need to replace the blader or maybe both?
FIXED
- Carel
- Full Name: Carel Vos
- Nickname: Carel
- Home Town: Germiston
- Current 4x4: 84 Safari
2001 Patrol 4.5 GRX - Home Language: Afrikaans
- Been thanked: 10 times
Cedric didn't want to ask, so how did you get a puncture and how did you fix it?
yeah I want to know too.... ( you never know when you might need this repair )
Seriously though... I presume that these bladders cannot be repaired due to the pressures achieved when inflated and then even more so when, for example, under full articulation.
- Full Name: Dries Erasmus
- Nickname: Dries
- Current 4x4: 2000 Patrol 4.2 GL
- Been thanked: 11 times
Only the punctured bladder needs to be replaced-cannot be repaired,did mine +/- 3months ago-Firestone product at megaworld.Cost=R1100 .
- Grant
- Full Name: Francis
- Nickname: Grant
- Home Town: Rosendal
- Has thanked: 3 times
- Been thanked: 26 times
Dirk,
Most of the time the air bladders get punctured is due to a very low pressure. Contact your nearest fitment centre and ask them to inquiry about a warranty. Normally the suppliers are more than happy to assist. Check you bladders regularly and keep inflated to a minimum of 1.5 to 2 bar.
- offroadbiker
- Nickname: ORB
Ouch, painful lesson to learn, worst part is I did not even know I had air suspension till I got the vehicle home and started a proper inspection, so do not know if it was like that when bought.
Will phone around and se what I can find out.
As for the warranty, would be difficult as I don't know who the supplier was and the fitment was done in Cape town.
- Has thanked: 1124 times
- Been thanked: 1038 times
Dirk, if you don't intend carrying heavy loads you could just remove both the bladders?
- offroadbiker
- Nickname: ORB
Peter Peter Peter............... are you actually suggesting that I REMOVE one of my gadgets from the Trol
That will never work, one must add not reduce gadgets, it would be like taking a toy from a 4 year old
I would just not be able to do that to my inner child
