Patrol 2012 3.0 GL KM/H @ 2000 rpm
Bekker
Full Name: Bekker van Niekerk
Nickname: Bekker
Home Town: Wellington Westren Cape
Current 4x4: None
Post by Bekker »
Hi All
I'm new to the forum and is looking into buying a Patrol 3.0 TD GL. I'm retired and got some time at hand and don't need the 4.8 GRX for speed and I'm also very conservative about km/l.
Can anybody tell me what is the road speed on std tyres 265/70/16 @ 2000 rpm on the 3.0 TD GL Patrol where you get the max torque. And also what is the torque range eg between what rpm ?
Thanks mates
Bekker van Niekerk
Wellington W/Cape
bekker@paarlrek.co.za
Bekker van Niekerk
0828017117
Re: Patrol 2012 3.0 GL KM/H @ 2000 rpm
Bekker.... Welcome to the forum.
I can't answer your questions, due to me having the 4.2 diesel...... but, soon you will have all the info you need as the guys get the fingertips working in this cold weather.
But from what I've seen, comparing now to my 4.2 diesel, the 3.0 diesel has very good power to weight ratio, a relatively quick pull away (probably quicker 0 - 100Km/h), and fantastic fuel economy. I would bear in mind that these motors were, emphasis on were, problematic. I do believe that Nissan has sorted out these issues, and there are a few modifications that, as a diesel driver, feel you should definitely look into. For example, a EGT Gauge (Exhaust Gas Temperature Gauge). My personal opinion, but with just this EGT gauge and correct servicing this Patrol will easily make its 500 000 km target.
You said that you are retired..... this patrol will make you feel 18 all over again..... :lol: :lol:
martyn
Full Name: Charles Fry
Nickname: Charlie
Home Town: Robertson
Current 4x4: Patrol 4.5
Has thanked: 83 times
Been thanked: 41 times
Post by martyn »
Hi Bekker, very shortly you will see a post from Grootseun, read it and take notes, he is a FUNDI on Patrols and will give you all the right answers.
Welcome and enjoy, there are a bunch of very knowlegable guys here. :thumbup: :oldtimer:
Diem Dulcem Habes
Have a good day
Silverfox
Full Name: Dave Wright
Nickname: Silverfox
Home Town: Benoni
Current 4x4: 2005 Patrol 6.0l LQ9 V8
2011 Disco 4 V8 HSE
Post by Silverfox »
I have a 2005 model. I'm not 100% sure but I think all the 3.0 are manual. Anyway with 265/75/16 at 2000RPM I am doing 120Kph according to GPS. With the 70's you will be doing 115kph.
Hmmm... yeah, good point. Driko ( Grootseun) has a 3.0 diesel that is auto, if I'm not mistaken.
Izak
Full Name: Izak
Nickname: Sakkie
Post by Izak »
Hello Bekker
When it comes to these Patrol I also defer to Grootseun (aka Dirko) but at least I can give you the following:
I have a 2003 Nissan with the 3.0 Di motor. On the last SAC day my stock standard Patrol with about 140 000 km gave the following output on the Dyano:
Torque: 1500 RPM 179.3
2000 RPM 283.2
2500 RPM 294.2
3000 RPM 285.4
3500 RPM 260.3
KW: 1500 RPM 25
2000 RPM 53
2500 RPM 70
3000 RPM 81
3500 RPM 86
On my Patrol with 265/75/16 at 3000 RPM I am about at 110 km/h and on a open highway driving I will get about 9.8/10.3 km/l.
Izak
DASTECH.pdf
(93.46 KiB) Downloaded 287 times
Bekker
Nickname: Bekker
Current 4x4: None
Post by Bekker »
Thanks all of you for the response to my questions. I believe I will get some more info from Grootseun once he read my post.
If I can get the km/h per 1000 rpm it will be much better.
Thanks & regards
Bekker van Niekerk
Wellington W/Cape
Bekker van Niekerk
0828017117
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
@ 100km/h the manual should be about 2600 and the auto about 2100 - have a look on the Ausie site Patrol4x4.com
Silverfox
Nickname: Silverfox
Home Town: Benoni
2011 Disco 4 V8 HSE
Post by Silverfox »
Silverfox wrote:I have a 2005 model. I'm not 100% sure but I think all the 3.0 are manual. Anyway with 265/75/16 at 2000RPM I am doing 120Kph according to GPS. With the 70's you will be doing 115kph.
I must apologise. At 3000RPM you will be doing 115kph. At 2000RPM you will be doing 77Kph. So you are looking at 38Kph per 1000RPM in 5th gear, assuming it is a manual
Silverfox
Nickname: Silverfox
Home Town: Benoni
2011 Disco 4 V8 HSE
Post by Silverfox »
David wrote:@ 100km/h the manual should be about 2600 and the auto about 2100 - have a look on the Ausie site Patrol4x4.com
That's correct with the manual. I can't say with the auto
