Sway Bar Link Pins
- Grant
- Full Name: Francis
- Nickname: Grant
- Home Town: Rosendal
- Has thanked: 3 times
- Been thanked: 26 times
Sway Bar Link Pins
I have a standard pair of anti swaybar link pins for a GQ avaiable to the first person that collects them.
Call me on zeroeightthreesixzerozerofourzerotwothree
Re: Sway Bar Link Pins
IS that for front or rear Grant... I recently replaced my rear links and probably need to do the fronts
- ChristoSlang
- Nickname: ChristoSlang
- Home Town: Pretoria, ZA
- Has thanked: 29 times
- Been thanked: 136 times
- Grant
- Nickname: Grant
Hi Cedric,
Front and Rear. I will hand tem over to you. If they do not fit, you can post and give to the next person.
- Jules
- Full Name: Julius
- Nickname: Jules
- Current 4x4: Pathfinder
- Has thanked: 94 times
- Been thanked: 76 times
Grant morning , what are these links suppose to do?
do they get worn that you replaced them or did you remove your swaybar
shalom
shalom
Jules, the sway bar links have a "tie rod end" on each side. Mine were so worn out that they almost rattled inside their housing. They do take a bit of a pounding when doing axle twisters as one side is trying to pull up and the other side pushing down.
It takes about 5 mins per side to remove old ones and replace
- Grant
- Nickname: Grant
Hi Cedric,
Just checked on the Aussie site and it seems they are specific for the GQ.
Cool man..... no hassle
