4.8 belts
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
4.8 belts
Post by David »
Hi - I saw Chris Skinner posted the question...
Here are the belts for a 2006 4.8 GRX
Fan Belt
This is a smooth V belt
Nissan part number:02117-07023
Alternator
This is a flat belt with 6 grooves
Nissan part number: 11720-VC200
Additional markings: 4-AF414
Aircon
This is a flat belt with 4 grooves
Nissan part number:11720-VJ200
Additional markings: 4-AF533
Re: 4.8 belts
Thanks man :thumbup:
NISMOnator
Full Name: Jacques Strauss
Nickname: NISMOnator
Has thanked: 19 times
Re: 4.8 belts
Post by NISMOnator »
Hi,
Are these the main belts that we need to do certain services for? Graham told me that if I intend to keep the Patrol for a long time I should start looking at getting some spares like the belts etc?
Where can they be bought and where would we get the best prices? For the 4.8 do you also have to buy the air filter from Nissan on can you replace it with a different one? Maybe K&N lifetime filter?
Still getting into all of this technical vehicle stuff. :eureka:
PS: Does the 4.8 GRX have a CAM BELT or a CAM CHAIN?
Thanks/Dankie :thumbup:
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Re: 4.8 belts
Post by AndriesS »
Power steering belt : RAM P473
4.8 use a chain drive for the cam
Has thanked: 1131 times
Been thanked: 1044 times
Re: 4.8 belts
If you intend using your Patrol only on the road and maybe to launch a boat once in a while, you can use the K&N, but if you drive dirt roads, rather stay away. Best yet, install a snorkel.
Re: 4.8 belts
K + N not a good idea :naughty:
Works well for 500km and then gets dirty had one better with snorkel even driving in jhb :mytwocents:
Grootseun
Full Name: Driko Henningse
Nickname: Grootseun
Re: 4.8 belts
Post by Grootseun »
Go snorkel and the OE filter , i had several K&N ones and even had made a custom enclosure with a snorkel - was crappy off road IMO , keep your existing filter setup and put a qaulity snorkel on there , just beware of most of the cheap imported snorkels they are cheap for a reason ill so safari one day when im big
2001 9.4 Patrol DI GRX
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
NISMOnator
Re: 4.8 belts
Waar is die beste plek in SA om parte te koop vir die Patrol 4.8? Die dealerships is blykbaar insane!!!
