CROWN & PINION GEARS!
G-MAN
Full Name: A.G.HOLMES
Nickname: G-MAN
Home Language: Engels
Been thanked: 9 times
Post by G-MAN »
Anyone know where i can get a set of crown & pinion gears that will suit 37 inch tyres. :helpsign:
Sucks Gas and Hauls Ass!
Saltman
Full Name: Herbie Hellstrom
Nickname: Saltman
Re: CROWN & PINION GEARS!
Post by Saltman »
Jeeez, just thought you had stripped a Patrol diff (not too often you hear about such an achievement) ... then I read the 37" tyre bit.
OK, to answer your question: Australia ? :blonde:
Saltman:
G-MAN
Nickname: G-MAN
Post by G-MAN »
You had me all excited! :blonde: Then you said Australia :doh:
G-MAN
Nickname: G-MAN
Post by G-MAN »
:helpsign: Any one know how to work out, diff ratio to wheel size? Wanna run 37 inch :biggrin: and what diff ratio would bring it back to standard. :think:
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser »
Hi G-MAN,
Your 4.8 GRX Auto came with a final drive ratio of 3.545:1 and 275/65R17 tyres as standard, if I am not mistaken.
The tyre nomenclature works as follows:
275: Nominal tyre section width in mm
65: Aspect ratio in % (the ratio between the height of the sidewall and the section width
R: Radial tyre construction
17: Nominal rim diameter in inches
The nominal diameter of your standard tyres (in inches) can be calculated as follows:
1) Calculate the height of the sidewall (in mm) by multiplying the section width by the aspect ratio (265mm x 65% = 178.75mm)
2) Calculate the height of the sidewall (in inches) by dividing the answer from 1) by 25.4 (178.75 / 25.4 = 7.037")
3) Calculate the nominal diameter by adding twice the sidewall height to the nominal rim diameter (2 x 7.037" + 17" = 31.075")
Now if you want to fit 37" tyres instead of the standard tyres, the gearing will become higher in the ratio of the tyre diameters. To compensate using final drive gearing, you will have to multiply the final drive reduction ratio by 37 / 31.075 = 1.191. Seeing as your current final drive ratio is 3.545:1, you will need a final drive ratio of 4.221:1.
Now as far as I know, the 4.8 GL manual comes with a final drive ratio of 4.375:1, so this might be an option. This will yield gearing that is 3.65% lower than standard.
The older manual 4.5 had a final drive ratio of 4.111:1, so if this ratio is used, you will have gearing that is 2.6% higher than standard.
I am not sure how interchangeable all these crown wheel and pinion sets are, so you will have to do some homework, but this should help to narrow things down a little.
One other point to note is that two different basic differential designs are used in the Y61 Patrol, namely the H233B and H260. The numbers refer to the diameter of the crown wheel in mm and in general the larger the crown wheel is, the stronger the diff. All the Y61s use a two-pinion version of the H233B diff in the front axle and all rear diffs are four-pinion, but only manual transmission 4.5s and the 4.8s, use the H260 rear diff. Patrols with the TD42 or ZD30DDTi motors have the same 4.111:1 ratio as the 4.5, but these have the H233B rear diff.
G-MAN
Nickname: G-MAN
Post by G-MAN »
:think: GERRIT jy is n guru op alles! :salute: Dankie .
Sickness
Full Name: Jared Chaser
Nickname: Dick
Home Town: cape town
Current 4x4: Ford F250,colt,hardbody,cruiser,chev k30
Home Language: pig
Post by Sickness »
Normally every 2' above standard up on gear ratio.Like 4.1 33s ,4.56 35s, 4.88 38's.So for you up two ,whatever they are.4.3/4.1
Engel
Full Name: Herman Engelbrecht
Nickname: Engel
Home Town: Kempton park
Current 4x4: MQ patrol
Gu Patrol
Triton
Home Language: maakiesaakie
Post by Engel »
I also want to change my gearing but the costs is astronomical. I have a 260 diff at the back [used to be 233] but lost ground clearance. Its ok on 33" but runs out of power on serious hills. So before i go 35" I must do the final drive change [or crawler gears]
Herman 0824453301
herman@angeloffroad.co.za
G-MAN
Nickname: G-MAN
Post by G-MAN »
Thanks Jared. :thumbup:
jakeslouw
Full Name: Jakes Louw
Nickname: Jakes
Home Town: De Wildt
Current 4x4: Jeep Wrangler
Has thanked: 28 times
Been thanked: 29 times
Post by jakeslouw »
The MQ has the C200 front diff?
What will a set of 4.11 gears cost for that diff? Can I find a diff with that ratio in South Africa?
