water in passenger foot well
- Full Name: Andries
- Nickname: None
- Home Town: Pretoorsdorp
- Has thanked: 28 times
- Been thanked: 38 times
I noticed some water in the passenger foot well after some big splashes from this mornings rain. I had it once before after a power wash. It feels like it is dripping from the fan box. I assume it's entering via the vents behind the bonnet , Are there draining holes or spalsh guard that I need to check for?
Re: water in passenger foot well
When that happend to mine it was the heater radiator that leaked!
- G-MAN
- Full Name: A.G.HOLMES
- Nickname: G-MAN
- Home Language: Engels
- Has thanked: 3 times
- Been thanked: 9 times
Andries if all else fails, get some goldfish!
Sucks Gas and Hauls Ass!
tell passenger to finish wee at home before travel starts and not to skrik so groot when you go through obstacles
- Aries66
- Full Name: Louis Naude
- Nickname: Aries66
- Been thanked: 3 times
HI Andries.
Check for blockadges on the sides off the top vents. Had the same thing happend on my old patrol, wife park under trees at work, the leaves and dust block the drainadge areas.
Louis
Louis
- marakasmalan
- Full Name: Marnus Malan
- Nickname: marakasmalan
- Current 4x4: '94 Patrol SGL
- Has thanked: 4 times
- Been thanked: 16 times
I disposed off half of the atlantis dunes' sand in Kempton Park, after moving here and realising water drainage/hot&cold air circulation was not working. Sand entered throught the vents in the bonnets after tackling a few dunes that was too steep for the ARB bumper...
- Full Name: Johan van Vuuren
- Nickname: Johan
- Home Town: Krugersdorp
- Current 4x4: Safari s/w
- Been thanked: 7 times
If the heater radiator is leaking you will smell the antifreeze the moment you open the vents. See that the drain pipe of the airconditioner at the bottom of the fan/evaporator is still in its place ,that is a common fault of water in the footwell
Johan
Johan
- Nickname: None
I found the problem. The little plastic widgets that hold the vent tray below the windscreen was broken when the windscreen was replaced. The 2nd, 3rd one from left enters the cabin directly and if they don;t seal you will be surprised on the amount of water that can enter.
