Belts are worn to hell, advice needed.
- Russ Kellermann
- Has thanked: 8 times
Guys, my belts are on the way out. I need new ones for my 4.2D. I've been to midas,suburban,tonnesons,commercial spares, you name it i've been there, none of them have listed belts for the patrols. Do i need to order these items from the dealers or has someone got a better idea, i'm at my wits end.
- Ross
- Full Name: Ross Holland
- Nickname: Ross
- Home Town: Cape Town
- Has thanked: 7 times
- Been thanked: 14 times
Re: Belts are worn to hell, advice needed.
Russ, the aftermarket guys do have the right belts, but you need to give them a sample, as (like most Trol stuff) its not listed so they don`t realize that they have it!!! I replaced all mine from the after market guys last year some time. I`ll dig around and see if I can find any part numbers for you. SRXy did the same before our Zambia trip last year, so between us we might be able to get the numbers you need. I`ll scratch around in the my garage and in the back of the van and see what I can dig up.....otherwise SRXy will be back from the UK at the weekend.
Ross
aka "The Polar Bear"
- Ross
- Nickname: Ross
Russ, I just discovered a full spare set of belts lurking in the back of the van that I had forgotten about!! I bought the extra set when I changed all the belts about 18months back. I can`t remember which of the aftermarket guys I bought them from, but it was most likely Suburban Spares in Ottery, or the Midas down the road from me in Tokai.
I`ve listed the part numbers below in order of length (longest to shortest), which I think is Power Steering, Alternator, Air-con but it`ll become clear when you pull the old ones off as to which goes where.
Goodyear/Ram (Gatorback) PG480
Goodyear/Ram (Gatorback) PG476
Goodyear/Ram (Gatorback) PG468
Hope that helps!
Ross
Hope that helps!
Ross
Ross
- Russ Kellermann
Ross you my absolute hero mate. I really appreciate that you went through the effort to find this for me, Thank you.
- Russ Kellermann
Belts are in, running like a dream.
- Ross
- Nickname: Ross
Ross
Mooi man
