Power Valve Actuator (PVA) Mod
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Re: Power Valve Actuator (PVA) Mod
Post by David »
NISMOnator wrote:Thank you David, :salute:
The arm I see on the right? Was that connected to the part that should be cable tied? Just unclip and leave it there? :think:
Yip - remove the small circlip and washer. Disconnect the arm and replace circlip & washer. Turn the butterfly clockwise till closed and cable tie in place. There is not much space so long nose pliers help :thumbup:
David
Nickname: David
Post by David »
Clem wrote:Right, so if it CLOSES the valve, what's really happening?
My understanding is that when the butterfly closes it actually lengthens your intake duct which in turn provides more bottom end torque and when it is open you will have more top end power :layrubber:
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Post by Clem »
Got it, thanks! Presumably then it would normally be closed anyway at idle and would open wide when overtaking under full throttle at high RPM ? Anyone know what it's normal behaviour would be?
Oellie
Full Name: R.oelofse
Nickname: Oellie
Home Town: Walkerville
Current 4x4: 2005 Patrol 4.8
Been thanked: 7 times
Post by Oellie »
Does this Mod only apply to the 4.8 ,can I do this mod on the 4.5 ?
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 17 times
Been thanked: 87 times
Post by Marino4x4 »
Hi Oellie
Ek het laas nag gekyk, dit lyk my of dit net op die 4.8 enjin is. Daar is nie iets wat soos dit lyk op die 4.5 nie. As iemand meer hiervan weet sal dit gaaf wees as hulle kan help. Dalk PC wat die afgelope paar weke die 4.5 bekyk het en nogmals bekyke het. :biggrin: :biggrin: :lol: :lol:
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Oellie
Nickname: Oellie
Post by Oellie »
Dankie :thumbup:
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser »
No, the TB45E does not have any of this fancy variable induction tract mallarky :biggrin: . It is a good honest old fork lift engine :thumbup: .
Blitzpatrollie
Full Name: Gavin Kukard
Nickname: Gavin
Home Town: Croc Valley Conservancy, Nelspruit
Current 4x4: 2003 Nissan Patrol 4.8 GRX Auto (Gold)
Been thanked: 9 times
Post by Blitzpatrollie »
Hi guys, I'm just about done burning off a full tank of juice on my first patrol, (didn't take long btw) and then wanna do this mod. On the aussie site they say something about a cable that needs to be disconnected. Is this a must, or optional? Don't really like the idea of having a loose cable hanging around in there...
NISMOnator
Full Name: Jacques Strauss
Nickname: NISMOnator
Has thanked: 19 times
Post by NISMOnator »
I also dont like the idea of a cable being unplugged and then just hanging in there? Can someone answer this?
Decided my mechanic should rather do the mod. :redface:
Has thanked: 1130 times
Been thanked: 1044 times
Most wiring harnesses have plugs that hang loose, put there for options or systems not fitted to that particular car.
Cable-tie it down somewhere...
:mytwocents:
