Symmetry 4WD 1997 Nissan Patrol Y60 GQ 4.2 SGL TB42S
symmetry4wd
Full Name: Andreas Schwerdtfeger
Nickname: Andreas
Home Town: cape town
Current 4x4: 97 GQ Y60 Patrol
Has thanked: 67 times
Been thanked: 29 times
Post by symmetry4wd »
Hi everyone,
Just a short introduction, my name is Andreas, from Cape Town. Hi :salute:
I picked up my Patrol this past friday, 11/11/2022. Here are the details:
Nissan Patrol 4.2 SGL
1997
TB42s/Carb
Manual
Metallic Green
Cloth Interior
No third row
Rear Diff Lock (need to fix/check)
232xxxKMS on the clock (Speedometer wasn't working when I got it, so the odometer wasn't either, actual mileage may vary, will do an eNatis vin check to get a rough idea of last sold mileage. Speedo fixed now)
15' Black Steelies, 31x10.5 R15 Hankook Dynapro MT
EFS Shocks and steering damper
no idea on the springs, but the rig looks about stock height
The car is in pretty good condition for the age, little niggles here and there as to be expected, but overall I am very happy with it!
This is my second 4x4, I let go of my fantastic 2000 Mitsubishi Pajero LWB 2.8TD NL Blister Fender (Long Travel Bilstein shocks, 3" Lift, 285/75 R16 BFG KM3's, Custom Steel Bumper) in order to purchase the Patrol, so far not regretting it one bit, though I still do like and miss the Pajero, it was a solid rig!
I have a YouTube channel documenting my 4WD adventures, builds, trails, DIY's etc. Any support, subscriptions, views, likes etc there would be much appreciated:
https://www.youtube.com/channel/UCklYHs ... MNnx-BttzA
Nissan Patrol content to soon follow!!! :woo:
Some immediate things to sort out on the car:
- Diagnose and fix rear diff lock
- Find and Fix coolant leak
- Fix coolant temp gauge
- Fix some dodgy wiring on Tcase and in engine bay
- Service
Here are the few pics of the new rig:
Spike
Full Name: Spike Pretorius
Nickname: Spike
Home Town: Milnerton
Home Language: Sleg soutpiel
Has thanked: 77 times
Been thanked: 87 times
Re: Symmetry 4WD 1997 Nissan Patrol Y60 GQ 4.2 SGL TB42S
Post by Spike »
Howzit. Already met via whatsapp :salute:
The diff-lock solenoids get rusty inside, usually just the bottom one, and the piston sticks. First thing to check.
:oldtimer:
Sardonic Fattist
symmetry4wd
Nickname: Andreas
Spike wrote: 14 Nov 2022 10:05 Howzit. Already met via whatsapp :salute:
Howdy :thumbup:
Thanks, going to tackle that soon, first busy with a coolant leak from a broken heater hose elbow under the thermostat housing :rolleyes:
Enjoy your patrol man let us know what we can help you with
Welcome to the Patrol Family !!... and congrats on the Patrol. You will miss the Pajero good fuel consumption, but you will never replicate the pleasure a Patrol can bring you... :wink:
Sweetlips
Full Name: Lawrence
Nickname: Sweetlips
Home Town: Paarl
Current 4x4: 2006 4.8 GRX
Has thanked: 47 times
Been thanked: 99 times
Post by Sweetlips »
Welcome to the forum Andreas. Here is a heap of knowledgeable gents available to you.
Has thanked: 198 times
Been thanked: 275 times
:welcomewave:
symmetry4wd
Nickname: Andreas
Thanks for all the welcomes! Appreciate it :salute:
I will definitely miss the Pajero, it was an awesome rig, and never skipped a beat, but yes, very excited to have the Patrol! Loving it, can't wait to get the leak fixed and burn some more fuel!
The old rig:
symmetry4wd
Nickname: Andreas
A little update on the build with some maintenance I carried out over the last week:
- Replaced all heater hose fittings on the engine, old ones were nasty!
- New fabricated intake manifold water hose pipe
- Replaced all the heater hoses, made up my own from the right ID/OD Coolant Hoses
- Replaced the fuel hoses
- Replaced quite a few vacuum lines, also put them in their right places, as they were a mess before
- New Coolant Temp Sender, Temp gauge now works
- Fixed wiring on the Transfer Case speed sensor to get the Speedometer working
- Fixed and cleaned up some bad earth's in the engine bay
- Fixed some wiring on the Transfer Case selector indicator
- Car was running super rich and lumpy after completing all the above, must have messed with the carb mixture adjustment screw by mistake during the work, tuned the carb a bit, and changed the spark plugs, all good now
More Maintenance to come soon!
Engine, Diffs, Tcase, Gearbox oils, fuel filer, oil filter, air filter.
Fix issue with rear D/Lock
etc etc etc!
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Post by Stefan »
Welcome Andreas! :biggrin:
Can't wait to see the wagon in person.
